Decaling and Future
    February 2007
Decaling and Future
Posted by aj2wins on Friday, April 20, 2007 8:32 PM
I sprayed my aircraft with future and Iam ready for the decaling
I have used Tamiya lite gray acrylic paint, for the primary color
Am I going to have a problem with the decaling by using future as the gloss coat?
I have the micro set solution and have read several articles on the process of applying
the decals, but after reading several articles about future I am not so sure about the
properties of the future and the acrylic paint. I have sprayed future about two days ago
so it should have had a long enough time to cure.
    January 2003
Posted by Triarius on Saturday, April 21, 2007 12:07 AM
Assuming you cleaned the plastic properly before applying the Tamiya paint, you should have no problem with decals. Some decal setting solutions will cloud Future, but a second application of Future after cleaning the excess solution away appears to solve the problem.
Personally, I've never had a problem with Future and Micro-set, or  Micro-Sol. But I never leave excess solution on the model, and my Future has always been thoroughly (sometimes months!) cured.
jwb
    February 2006
Posted by jwb on Sunday, April 22, 2007 8:40 PM
I can ditto Ross' confidence in Future, and from a slightly more reckless viewpoint. Shock [:O] I sprayed on 3 coats of Future this afternoon on a Spitfire, and decaled it this evening. Whistling [:-^]
I used PollyScale Decal Solvent to zap the decals into submission.
Now- I'm certainly not suggesting you do as I do..... I probably should've had more patience and given the Future at least a day... I was just bored. LOL
Suffice to say- you should have a good experience if you use Future as a gloss coat before your decals. Recklessness not recommended....
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
