Nice......frickin' decals from Revell
    January 2006
Posted by dirkpitt77 on Tuesday, April 24, 2007 8:15 PM
     So, I've been working on Revell's '99 Chevy pickup for about six months now, in between taking care of my kid and other life duties.  I get everything perfect on it-custom license plates, tinted windows, EVERYTHING.   Then I go to put the decals on.  Now, in the instructions, it says the following: "Notice: these decals are not compatible with decal setting solutions."   So, wanting to know HOW exactly, they were incompatible, I cut a spare from the sheet to experiment on.  Applied it to a greebly with some odd surface detail, throw on some Micro Set and Sol, and wait. And wait.  And wait.   Nothing happened.  So I found out that by "not compatible", they meant "solutions don't work on these at all".   Grrrrr.....so I dropped back and punted, throwing down some Future and setting them that way.  At first they looked ok, but they had to go over raised surface detail, so now they just sit on top of it, flat, without snugging down at all.   A perfect model ruined by imperfect details.  I'm about to write Revell and lay the smack down on 'em.
    So, anybody know where to get aftermarket Chevy logo and emblem decals?
  Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    March 2007
Posted by f14 tomcat freak on Friday, April 27, 2007 7:59 PM
the smackdown??
 ANYTIME BABY !
Posted by Anonymous on Friday, April 27, 2007 9:42 PM
One thing you could try is to get a rag, dip it into warm/hot water and hold it on the decal and the decal should soften and conform to the curves. I have only heard of this technique but have yet to try it, but if your out of any other options, you could give this a try. This probally goes without saying but don't use boiling water and be careful because hot water could soften the plastic and warp your model if your not careful.
I hope this helps.
    August 2006
Posted by wyoroy on Saturday, April 28, 2007 10:52 AM
dirkpitt77,
Check your PM.
Roy
Roy (Capt. Wyoroy FAAGB/USNFAWGB)
John 3:16
    January 2006
Posted by PatlaborUnit1 on Sunday, April 29, 2007 12:32 PM
Hot water ALWAYS works..it gets the decal warm enough to be flexible.
I have had the same compliaint with some Tamiya decals, they sit on top of the detail and laugh at you. Now that Im using hot water I rarely grab the Micro bottles.
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Sunday, April 29, 2007 2:52 PM
David
Good info, Dave. Thanks for the heads up. I have heard the same thing about Hasegawa decals, and will try the hot water trick next time I use them. ( I like aftermarket stuff, but just can't justify buying aftermarket decals for EVERY kit ).
Andy
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
    February 2006
Posted by Wilbur Wright on Sunday, April 29, 2007 5:59 PM
I have to tell you guys that Revell came through for me after I screwed up my 1/72 scale B36 finishing job.
I wrote, and a month later had a new sheet of decals. A rather large sheet for that model as well.
    January 2005
Posted by bujinin on Tuesday, May 1, 2007 7:54 AM
when i still had a functioning olfactory sensor, i whiffed the odor of acetic acid/vinegar from a decal setting solution. the other day i tried using white vinegar on some ageing hoosegowa stars and bars and it worked wonderfully, which leads me to suspect those solutions are just expensive pickle juice. keep'em dryin' [at least 24 hours under temperate conditions]
former hazmat specialist, lexicographer, semi-pro actor
