Decals that have yellowed
    February 2006
Posted by PALADIN on Saturday, May 12, 2007 2:50 PM
I recently found some older Dragon - "Knights of the Skies Collection"  still in the box but sadly the decals have yellowed. Does anyone have any tips that may restore decals to the clear state that they had when they were new?
Thanks,
PALADIN
    November 2006
Posted by ww2modeler on Saturday, May 12, 2007 6:08 PM
I heard that if you tape them up to a window facing the sun for a couple of weeks they will turn "normal" again.
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
    January 2003
Posted by Triarius on Saturday, May 12, 2007 7:50 PM
David is correct. You may also want to recoat them with decal adhesive (after sun-bleaching), available from several sources.
Don't leave them too long—the sun will fade the other colors, too.
    February 2006
Posted by ruddratt on Saturday, May 12, 2007 11:17 PM
Ross, what is this adhesive you talk about, and how does it work? Does it soak through to the side of the decal that needs it, or is it something similar to the micro-scale clear decal film that I brush over decals to keep them from shattering? TIA.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    February 2006
Posted by PALADIN on Sunday, May 13, 2007 4:13 AM
I will give that a try.
 Thanks,
PALADIN
    January 2003
Posted by Triarius on Sunday, May 13, 2007 9:53 AM
Mike,
 AAaacckk!
Not sure why I said "adhesive" when I meant "clear coat!" Sorry for the confusion! Must have been distracted, asleep, something!
    February 2006
Posted by ruddratt on Sunday, May 13, 2007 1:27 PM
Hey, no problem Ross! Been there many a time. Big Smile [:D]
    March 2005
Posted by mfsob on Monday, May 14, 2007 11:13 AM
The "taping them to the window" trick does work, IF it's a window that gets at least a couple of hours of direct sunlight every day, so pick one that faces as nearly east or west as you can. And do check the sheet every week or so, because the process is highly variable.
One thing I learned the hard way - to avoid even the remote chance of condensation forming between the decal sheet and the window, and ruining the decals, I tape a strip of cardboard at the top and bottom of the sheet to act as a "spacer" between the glass and the decal sheet. Alternatively, if the decal sheet is curled anyway, you can tape it in such a way that the curled ends hold the rest of the sheet away from the glass.
