Raptor
As far as I know, once you hit the decal with Micro-Sol, it will wrinkle somewhat but should even out as it dries. However as I have discovered recently, it doesn't always even out as it dries!
Maybe I did something wrong, I smothered the decals with Micro-Sol (can you use too much?), went to bed with a smug look on my face expecting an excellent decal job. When I looked in the morning the decals were mostly very good but there were a few areas of wrinkling. Guess I should have smoothed the decals out as the solution dried...
From now on I'll use the Micro-Set, monitor how it looks, and use the Sol sparingly, if at all.
I've used Future previously and it worked well, although the decals looked a little more raised on the surface than they do with the Micro Set/Sol system.
Glen
