flat paint under decals
    July 2013
Posted by DURR on Monday, August 13, 2007 9:58 AM
i (we) all know that you are supposed to use gloss under decals then once on you can do what you want.
i have been modeling for over 40 yrs,   i only found out about this in the last 15 or so.
i was going thru junk in the cellar and found a small box with models from 25-27 yrs ago. the decals were still on solid,  and the way i used to do it was just put them over flat paint then cover with a flat coat. the flat overcoat sealed them up good
    April 2005
Posted by T_Terrific on Monday, August 13, 2007 10:12 AM
Actually, although it is the conventional wisdom to gloss the area you apply a decal to, it is not absolutely necessary.
If I am applying decals that are large and on the heavy or thick side, and the flat coat is not actually rough, I usually just let the slime that comes on the decal do the job. This worked fine for a 1/32 Hase Mustang I recently did.
In a recent FSM build article, the modeler simply applied mixed some water and Future to the spot where the decal was supposed to go, and applied the decal before the mix dried and it worked out fine.
If I am working with special art work or long stripes for decals, I will go ahead and gloss the area first, just ot make sure.
If the kit comes in a color I already like, I apply them straight to the unpainted plastic, like with a Monogram SR-71, or the Academy Korean War F4U-4, then clear coat over them when they're dry.
I don't always use decal setting solution, either.
 Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    July 2013
Posted by DURR on Monday, August 13, 2007 10:25 AM
In a recent FSM build article, the modeler simply applied mixed some water and Future to the spot where the decal was supposed to go, and applied the decal before the mix dried and it worked out fine. make sure.
 Tom Cowboy [C):-)]
the only thing about the fsm article is  that future was used  (aka)  gloss coat
    April 2005
Posted by T_Terrific on Tuesday, August 14, 2007 3:45 PM
Depends on which article you are referring to DURR.
Usually it is used as a decal prep and/or sealer, and then the modeler often finish-coats the subject with Model Master flats, etc.
See Darren Roberts November '06 aritcle titled "Top Gun +20"
Tom Cowboy [C):-)]
Tom TCowboy
