Ant wrote: |
tried to use futre and tamiya flat base for the first time last night. i mixed the flat base in at a few drops at a time until i had the flat i wanted, so i dont think i used too much. i thinned the flat base before use as it was very thick, used water. idea's please? as you can see by my other posts i just dont seem to be able to do anything with future without a problem.!!! might be time to go back to using enamel gloss and dullcoat |
Have you read Matt Swann's "The Complete Future" ? If not, read it. If you have, read the technique sections again.
At least one of your problems is due to thinning the flat base. Don't. The stuff is thixotropic and will liquify with stirring. Adding water will create havoc with both the flat base and Future, as neither is formulated to be reduced with water. Use 90% isopropyl alcohol for thinning Future.
Also, I don't recall you mentioning what paint you were covering. Both enamel and acrylic gloss paints sometimes have "gloss enhancers" (usually a silicone) that will play hob with adhesion of overlying coats—hence the crazing. To overcome this, wash the surface with ordinary soap (like Woolite) and deionized or distilled water. Do not use detergent.
