First Decaling Job in Years
    October 2007
Posted by Careos on Sunday, October 14, 2007 10:37 PM
Hey all,
I am doing my first job in a very very long time and having some issues. This kit is bordering on 7 years old, I am using micro set and micro sol, etc yet the edges on some decals are lifting up. I tried to trim the lifted up portion only for the fresh edge to now lift...what is going on here?
http://picasaweb.google.com/jsharpcsa/MyModels/photo#5121402436197284322
    May 2005
Posted by Bgrigg on Sunday, October 14, 2007 11:13 PM
Could be a few reasons. The decals are old or you soaked them for too long and washed off the adhesive, or you're driving too fast (Mischief [:-,]) . Try brushing some Future (yes, the floor finish) under the lifted edges to assist the decal in sticking to the model, then spraying more future over the kit as a gloss coat.
So long folks!
    October 2007
Posted by Careos on Sunday, October 14, 2007 11:15 PM
Will do, I hope I can get this straightened out....hate to ruin a good model.
 So try future, even though the body is automotive gloss paint?
    May 2005
Posted by Bgrigg on Sunday, October 14, 2007 11:24 PM
Sure, why not? Future will (hopefully) stick the decal down, but to be really safe do a flood coat with it. Gives the decals the "painted on" look.
You could use any clear coat of your choice. I like Future, it's cheap and works.
So long folks!
    October 2007
Posted by Careos on Monday, October 15, 2007 7:41 AM
Okay, should I just brush some on? I have never really used Future and was concerned about runs, etc.
    May 2005
Posted by Bgrigg on Monday, October 15, 2007 9:21 AM
If you have an airbrush, it's easily sprayed. Future is really nothing more than a clear acrylic paint, even if some people think its for floors. Like all paints it runs when laid on too thick. If you managed to lay down a nice coat using auto paints, you'll have no trouble.
It can be brushed, but use a CLEAN wide brush. Future has excellent self levelling properties. Much better than pigmented paint. I suspect that has to do with the lack of pigments in Future.
If you are more comfortable using a "regular" clear coat, by all means use them. Let the Future cure for a minimum of 24 hours after fixing the decal. This will also let you know if it worked or not.
So long folks!
    October 2007
Posted by Careos on Monday, October 15, 2007 5:07 PM
I went ahead and used a smaller brush to lift up the decal edge and force the future underneath it, it looks like it might have fixed it. I then took some future and spread it over the side pretty thick with a flat brush, hopefully it will level out and go from there. I am going to stop progress on the model until I get this resolved....well progress as far as the body goes.
I never thought this would have worked, I definately appreciate the help.
    October 2007
Posted by Careos on Monday, October 15, 2007 6:32 PM
And the results...
http://picasaweb.google.com/jsharpcsa/MyModels/photo#5121710509906459122
http://picasaweb.google.com/jsharpcsa/MyModels/photo#5121710522791361026
I only wish that I would have figured this out before I screwed up the rockerpanel trim...oh well....I can always layer something there to cover it. Not bad for someone who hasn't laid a decal for over 15 years or so.
