I have a heck of a time getting large decals to lay down flat. I am currently working on a Hasegawa 1/32 Fw-190. I am using the kit-supplied decals. The smaller decals worked out fine, but the wing and fuselage Balkenkreuz gave me a lot of problems. I used Micro Set/Micro Sol on them. When I put the Micro Sol on them, they wrinkle like expected, but I can't get them to completely flatten out when they dry. Even after repeated applications of Micro Sol, I still end up with small wrinkles in the decal. I also had a similar problem with the tail swastikas.
Has anyone else experienced this problem? Am I doing something wrong? Is there a better decal setting solution for larger decals such as these?
Russ
