Decals setting solution alternative
Posted by Anonymous on Thursday, February 20, 2003 12:47 PM
I've run out of Testor's decal's solution and the local supplier doesn't have it either. What would be a good alternative. Please take into account that I don't have a Dupont's industry across the street. Household supplies would be great.. somebody told me about vinegar but it didn't work for me
Posted by berny13 on Thursday, February 20, 2003 3:09 PM
Use white glue. When I ran out of setting solution someone told me to mix 1 to 5 white glue and water. It worked, but be sure you wipe off any extra glue around the decal. Also be sure to seal the decal as it isn't waterproof.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Anonymous on Friday, February 21, 2003 8:25 AM
Thanks, that's a good idea, but my problem is how to thin the decal so it can follow the surface pattern.
Posted by Anonymous on Friday, February 21, 2003 3:20 PM
It's gonna sound dumb. But it works. DISTILLED VINEGAR. Next time you buy your Testors stuff, take a big whiff, what does it smell like. Straight vinegar is an okay subsitute, you may have to play with it for a while, but it will work.
Posted by jcarlberg on Saturday, February 22, 2003 10:22 AM
For a very strong setting solution, try diluted isopropyl alcohol. I would maybe also put a drop of dishwashing soap or chemical wetting agent in the solution, and I would experiment with less valued decals to get the solution right.
Posted by Anonymous on Sunday, February 23, 2003 6:27 AM
Decal setting solution is primarily acetic acid. Vinegar is close enough to the same thing.
I'd suggest diluted white vinegar.
