Tip
Tip
Posted by Anonymous on Monday, November 10, 2003 10:40 PM
I have a tip I would like to share with all of you. Or maybe someone has a better way Smile [:)]. I use a coffee cup warmer ( the kind you would use to keep your cup of coffee warm while you are working at your desk ). And a stainless steel bowl which just fits nicely with the coffee cup warmer. This combination keeps my white glue/ water mixture nice and warm while I apply decals. It has worked very good for me. Wink [;)]
Posted by Woody on Monday, November 10, 2003 11:27 PM
Sounds interesting. Does it help soften the decal so it settles down better? I too like to use a little white glue/water mix to improve adhesion and eliminate any silvering.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Tuesday, November 11, 2003 5:47 PM
Woody I do believe it does soften the decal somewhat. It seams to apply better in the warm water glue solution. It was the way I was taught years ago. It works for me And I need all help I can get when it comes to decals.
Posted by Woody on Tuesday, November 11, 2003 5:50 PM
I'll give it a whirl and see if it's moe better, warm! Big Smile [:D]
Posted by snobrd13 on Friday, November 14, 2003 9:58 AM
Hi guys,
Interesting discussion. Can you give me an approximate proportion of white glue to water?
Thanks,
snobrd13
Posted by Woody on Friday, November 14, 2003 12:25 PM
I use about 1part glue to 2-3parts water. I really just eyeball it but that's about right. Experiment on a flat(matte finish) painted surface-No silvering.Wink [;)]
Posted by Anonymous on Saturday, November 15, 2003 1:41 AM
I've ben around for a while and this is the first I've heard of using White glue s adecal setter. I've got try this SOON! I've got several pieces to choose from that are waiting for decaling. (and I'm out of Gloss Coat right now).
Posted by Woody on Saturday, November 15, 2003 3:06 AM
pathfinder, make sure you blot up any extra solution after you have the decal placed. After a flat top coat you shouldn't have any worries of silvering which is really just air trapped under the decal film. The glue/water solution doesn't have the same surface tension so it doesn't support micro air bubbles. Let us know how you like it.
Posted by Anonymous on Wednesday, November 19, 2003 9:19 AM
What does the whit glue and water mixture do exactlyQuestion [?]
Is it elmers glue?
Posted by Woody on Wednesday, November 19, 2003 7:11 PM
Hey parfectputter, Have you ever had a decal that went on ok but had a silverish hue to the clear part? The glue elimanates that and it also helps when the quality of the decal glue is poor. Elmers is what I use but don't get the "School Glue".Wink [;)]
Posted by Anonymous on Wednesday, November 19, 2003 10:34 PM
Sign - Ditto [#ditto] to Woody
Posted by Anonymous on Tuesday, November 25, 2003 4:38 PM
Do I hear my eyes correctly? No silvering at all with the glue solution? even on a flat finish?
wow...now i can use my last bit of future on my canopy instead of coating the whole plane in it!! Big Smile [:D]
-Dave
