i recently bought 2 leather punch sets from my LHS.
they are from "The Leather Factory".
they are called "Maxi Punch Set with Changeable Tubes"
part numbers 3004 & 3003
the one set (#3003) has 6 tips sized 5/64, 3/32, 1/8, 9/64, 5/32, 11/64
which is 'leather' size 0,1,2,3,4,5
for you metric fans, they also give sizes (2mm, 2.5mm,3mm,3.5mm,4mm,5mm)
but they are rounding as the next set will reveal.
it was $9
the second one (#3004) has 6 more tips sized 3/16, 13/64, 7/32, 1/4, 17/64, 5/16
('leather' sizes 6,7,8,9,10,12)
metric sizes given as 5mm,5.5mm,6mm,6.5mm,7mm,8mm
(notice the two sets bot have a "5mm" one is 11/64, the other 3/16 or 12/64)
it was $10.
i was using it yesterday on styrene and it worked quite nicely,
but i will point out a design element that might be a problem for modeling use:
the sides of the tube have a slight taper.
this is not a problem if you are using the disc you punched out.
but it could make the 'hole' bigger than you intend if you are using that side.
i was trying to make small rings by punching a disc, then punching a hole in the center.
it worked ok w/ larger sizes, but w/ the small size, the taper would snap the very narrow ring.
like everything else, you pays your money and you makes your choices.
ed.
