Putty and liquid glue recommendations
Posted by MikeV on Sunday, December 21, 2003 12:02 PM
This has probably been asked a hundred times so my appologies if it has.
Maybe I should just look through the archives for the answer. Dunce [D)]
I am in need of these two supplies and wanted to go to the hobby shop today and pick these two things up.
My tube of Squadron green putty dried up since I've had it for many years so I need to get some new putty. I was looking at the web site for the local Hobbytown USA near me and they have Testor's red putty as well as Tamiya putty. Which would be a better choice, or should I just wait until next week and go to my standard hobby shop and get some squadron white putty?
Also, what liquid cement is best? I had a bottle of Tenax 7R years ago and really liked how quick it works, although it does tend to evaporate rather quickly if left open very long. Is this still considered the best fast, liquid cement out there or would you recommend something else?
HobbyTown USA may or may not have Tenax 7R but they have Ambroid ProWeld on their web site. Is there any difference?
I do have an old bottle of Pactra liquod cement in the bottle with the brush in the lid but it stinks like acetone and is a bit messy.
Thanks
    January 2003
Posted by shermanfreak on Sunday, December 21, 2003 1:14 PM
Of the 2 choices of putty that you have listed Mike, I'd pick the Tamiya without even thinking twice about. It's a great product to work with.
I don't use liquid cements (strictly a CA kinda guy) but both Tenax-7 and Ambroid Pro-Weld have good reputations with the modelling world.
Posted by MikeV on Sunday, December 21, 2003 1:23 PM
Thanks brother. Wink [;)]
Posted by Anonymous on Sunday, December 21, 2003 8:37 PM
Mike. As you surely know, everyone has their own preferences. Mine are:
Putties: Bondo Spot/Glaze putty or Tamiya putty
Glues: Ambroid Pro-Weld and occasionally CA.
Murray
Posted by Anonymous on Sunday, December 21, 2003 8:46 PM
Putty: Tamiya or Gunze(prefer Gunze prethinned), the others I use you would have to order via HLJ or similar web-site.
Glue: Tamiya(thick and thin), I use the WAVE Superglue(CA) comes in strong and quick setting, dries clear & no smell. Each set also comes with some K-nozzles.
Posted by MikeV on Monday, December 22, 2003 4:01 AM
How does the Squadron white putty compare to the Tamiya?
The hobby store I was at today only had the Squadron white.
Posted by Anonymous on Monday, December 22, 2003 4:25 AM
Mike I guess it really depends on what your using the putty for....
I have squadron grn/white and Tamiya Epoxy putty....Im not sure if this is the same Tamiya putty the others are reffering to.
I still like squadron putty and employ the method of "fencing" to fill seams which Swanny shares on his website....works great
I have just started to use the Tam epoxy putty for a few things...filling gaps where you can sandwhich the putty in between the 2 parts then trim off the excess works great for that....I have yet to use it for other things, Im sure it has many more uses, but I have yet to discover them as I just bought some a few weeks back.
    May 2003
Posted by styrene on Monday, December 22, 2003 6:00 AM
Mike,
To each their own: I really like the Tamiya putty, but I also really like my DuPont lacquer putty (used in auto refinishing/painting). I bought a big tube for about $18 12 years ago, and still have over half a tube left. The stuff is very fine, and sands out well. Basically all it is is a thickened primer. Stuff's available at most paint stores. A similar product is 3M's acryl blue putty.
As far as glues, I use both Testor's liquid and Tamiya's liquid cement (extra thin). The Tesor's seems to set up a little slower than the Tamiya, but both are excellent products.
Hope this helps.
Gip Winecoff
Posted by MikeV on Monday, December 22, 2003 11:43 AM
Chris,
No, that is an epoxy putty. I was referring to the regular Tamiya putty.
I think they make three different ones including the one you mentioned.
Gip,
Thanks for the tips. I think I will just buy the Squadron white as that is what the hobby shop sells. I will probably give several a try over time to see what I prefer.
I appreciate the help from both of you as well as everyone else Wink [;)]
Posted by Anonymous on Monday, December 22, 2003 1:29 PM
Hey Mike,
One small tip. When using putties like this (the ones that dry by evaporation), put them on in several *thin* layers rather than try to fill a hole all in one clump. They tend to shrink a bit over time and that can be really annoying when you notice it 2 weeks after your masterpiece is finished. Using thin layers really helps them dry quicker and pretty much eliminates any shrinking.
Murray
Posted by MikeV on Monday, December 22, 2003 2:39 PM
Thanks for the tip Murray. I appreciate it. Smile [:)]
Posted by MikeV on Tuesday, December 23, 2003 5:04 PM
Well I made a trip to the LHS this morning and bought some Squadron white putty as that is all they carry, along with the Testors red putty which I know nothing about.
I'll have to try it out and see how I like it. I imagine it is smoother than the green correct? Why do they make both the white and the green? Are they suited better for certain uses?
    July 2003
Posted by Daprophet on Tuesday, December 23, 2003 6:32 PM
I have never used the green squadron putty, but as I understand it, the white putty is easier to paint over than the green is. I have also had the white putty craze plastic on me. I was told I could prevent that with the green. I am not sure if there is a different main chemical in the green or not. (white is toluene based).
God Bless
Dave
Posted by MikeV on Tuesday, December 23, 2003 10:21 PM
Thanks Dave.
The green is also Toluene based as I had some before.
It looks to me like the green may be a bit thicker in consistancy, but I nay be wrong. Maybe an old pro could enlighten us on this subject. Wink [;)]
    May 2003
Posted by qmiester on Sunday, December 28, 2003 7:14 PM
I agree with Gyp on the DuPont laquer based putty. You can get it at just about any good auto supply store. My local auto supply carries two different colors of the stuff. A green which is super fast drying (you can sand w/in 2 minutes of application) and a red (which I use most of the time) which can be sanded w/in an hour of application (i usually let it dry overnight to take care of shrinkage). Been using it for years.
For liquid cement I use a product called Pleximent (Pleximent Chloride). It was origionally designed for gluing plexiglass parts together and then someone started bottling it in 2 0z bottles and selling it in hobby shops as IPS WeldOn #3 at $2.95 a bottle. About ten years ago I found that I could buy a quart of it for $4.95. A quart lasts about 2 1/2 to 3 years. The only problem now is it is no longer available in quarts, just by the gallon ($25.95 a gal). Check your yellow pages for a plastic distributor and give them a call, they should be able to help you.
Quincy
Posted by Anonymous on Sunday, December 28, 2003 9:39 PM
Great info on the Putty and Glue.
I have used the testors white putty years ago when I was doing a lot of kit building.
It worked pretty good. Now after reading here, I will be sure to try some of the other putty ideas.
As far as glue, I did use some Tenax 7R. I have used a super glue called insta-cure+.
Also, If you are working on metal figures using Insta-cure+, try Insta-set.
Its in a mini spray bottle and you can almost hear the glue drying set.
Going to try insta-cure and insta-set on some plastic.
Will let you know how it works.
Thanks, Chuck
Posted by Anonymous on Tuesday, December 30, 2003 6:47 AM
I like the Mr Liquid putty, Humbrol and Revell paste.
For CA I use LOGO and a strange one with no brand name on it sold by the bucket (5x volume of the regular 5cc tube at the same price) but apparently it is really good.
Posted by Anonymous on Thursday, January 1, 2004 7:11 PM
I'd really like to know some expert info on the differences between Squandron White and Green myself.
After hearing praise for Squandron putty, I tried the green and wasn't totally satisfied with it. It seemed to me to be similar in composition to the Bondo Red Glazing putty but a little thicker and it seemed to dry even quicker. I might want to try the white if there are big differences. I've also been hearing for years about the Acryl Blue putties but have never gotten around to buying a tube. I think I'm going to try to find some tomorrow.
As for the Testors red putty in the big tube...I'll let you in on what I believe may be a little secret.....
I believe (and I'm not stating this as fact) that the Testors Red putty and Bondo Red putty are THE VERY SAME PUTTY, only packaged and marketed differently. Besides the fact that they physically appear the same and the tubes look to be about the same, both Testors and Bondo are owned by the RPM Corporation. It would make sense to find a dual purpose for an already formulated filler product that the company makes.
All I know is that the Bondo in the automotive aisle at Wal-Mart costs about half what the Testors costs anywhere else. Less than 2 dollars for a tube that's about 3 times the size of a tube of Squadron.Big Smile [:D]
Posted by MikeV on Thursday, January 1, 2004 8:03 PM
SFPROPS,
That was an interesting assessment there. Wink [;)]
I have used the Squadron Green putty and I just bought this tube of the white and from what I have seen so far I would say the white is finer grained than the green, although my tube is a bit old and had to be stirred to get it mixed back together as it was too much in liquid form.
Posted by Anonymous on Thursday, January 1, 2004 8:57 PM
QUOTE: Originally posted by MikeV
SFPROPS,
I've never had a tube of each on hand at the same time, so take my observations with a grain of salt....but I think based on the evidence I've mentioned, the coincidences concerning the similarities between the two putties are more than enough to make you go...hmmmm. Wink [;)]
Before I'd tried the Bondo I'd used the Testors white ...which...leaves a lot to be desired, in my opinion. Then I'd tried the Sq. Green. Out of the three, the Bondo Red has been the best thus far. I've tried using CA as a filler, though with really poor results (a mess).
I think that in addition to the 3M acryl blue, I'll have to try the Squandron White now.! THANKS!
    May 2003
Posted by DrCemento on Tuesday, January 20, 2004 11:57 AM
I've always used squadron white and never really been satisfied with how it sands out- especially on natural metal finishes where a perfect surface is required! gonna try a couple of others- guess all it took was knowing what was out there! It's a crying shame that hobby shops stock so little in this country - move to NZ even to see some hobby shops that will blow you away - it's all there in one spot with lots of people to talk to! Support your local shop and buy lots of stuff so he buys more stuff!!!!
Model builder formerly posting as jbatesc6
    June 2003
Posted by M1abramsRules on Tuesday, January 20, 2004 1:44 PM
squadron white is supposedly guarenteed not to shrink.
    January 2004
Posted by keeg on Tuesday, January 20, 2004 5:26 PM
Can I ask what "CA" is?
Sorry, I'm new to all of this and thank goodness for all the info everyone puts forth, it really helps the new guys like me.
Thanks Thumbs Up [tup]
Posted by MikeV on Tuesday, January 20, 2004 8:11 PM
CA is an abbreviation for CyanoAcrylate which is an ingredient in super glues like Zap.
    January 2004
Posted by keeg on Wednesday, January 21, 2004 1:10 AM
Thanks Mike!
