QUOTE: Originally posted by Murray Kish
I actually dip it into the glue and just 'suck' the glue up the tube (like a straw). Just don't go to fast or you'll have a mouthful. I stop when the liquid is about 2" from my mouth and that much glue lasts quite a while.
One small tip I've learned. Sometimes the plastic from the model can clog the tip. I've found that if I just drag the tip along a paper towel or kleanex after each use, it releases some glue and clears the tip. It's a quick, easy little habit and I've never had a problem since. If it does clog up, a dip in some laquer thinner will usually clear it.
Chris is right though, keep the tube because it's quite fragile. I've broken one already.
PS, DO NOT try to use this thing with extra-thin CA. It will ruin it..... (don't ask me how I know....)
Murray
Wow Murray, your a pretty brave man! No offense, I had thought about the suck method......well while using the applicator, I had it in my mouth holding it and like a dummy took a breath in through my mouth MMMMMMM yummy a mouthful of PROWELD! ACK
I immediatly spit it out without swallowing any thank God.
Really didnt suffer any ill effects from it other than the horrid taste and burning sensation.[:0]
As far as the clogs go murray's right that generally fixes it but what I actually do is put the needle back in the bottle tip down(if using Tenax or Proweld) and then pull it out after about a second or 2 and wipe the tip with my finger. By putting the needle in the bottle the Tenax or Proweld will actually 99.9% remove the clog for you.
Glad Murray mentioned the CA as I forgot to and I ruined my 1st applicator that way. NO CA at all....however I do ocassionaly run some Debonder through it to unglue a completely dry CA joint. The second one was lost due to the cap incident explained earlier.
Mike you might also want to check out ScaleHobby and see what Steve's prices are....I know he has free shipping on his finishing supplies. I cant remember if the applicator and Tenax would be in this category or not....
