ludwig113 wrote: |
sorry it took so long to get back to you, i brushed it. paul |
Thanks Paul. I assume you thinned it a bit. Is that correct? I haven't tried brushing Tam before but for small areas to be shadowed or weathered and if thinned sounds like it does a good job. Reading some of Brett Green's writings lately I've noticed that he also will brush Tamiya for certain applications.
JamesDean wrote: |
Despite being marketed as "ready to use", I find that the Vallejo washes are so intense color wise they can stand to be thinned 1:1 with water. Over a gloss clear coat they run very well for me into panel lines and any excess is easily wiped off with a wet cotton swab once the wash has dried to the touch. |
Hi JD,
Thanks for your input also. I've had others suggest that having a gloss coat on is the way to go especially if you want to have a chance at correcting to heavy of an application.
Thanks again to every one for taking the time to respond to the question. It's appreciated very much.
CUL,
Patrick
