Q:. Air-Pressure Regulator
I have an air compressor I used for working on cars; now I would like to use it for painting models.
Problem is, where the on/off switch is at, (a black box) that's where the quick connect is for the air hose and I wanted to put an Air-Pressure regulator there but it doesn't fit.
[not enough room between where the regulator would screw in and tank]
Do they sell extensions or something so that I could move the regulator out 2 to 3 inches to make it fit?
*** Campbell Hausfeld Up-Right Compressor 5 Hp - 26 gal. tank
Thanks, Andy
