Cutting tool help
    May 2006
Cutting tool help
Posted by aagranata on Monday, November 23, 2009 11:53 PM
I very seldom need to cut any parts in my models, but occassionally I would like to cut a canopy to display it open.  Also, my Italeri USS Ronald Reagan requires me to cut off the bow and replace with a new bow provided in the kit.  I know nothing about cutting tools.  What would be a good, cheap tool for achieving these cuts cleanly?
Also, I have a Sword T-38 that has several resin cockpit parts.  How do I get that big block of excess resin off the parts??
One good hour working on a model erases 8 bad hours at work!!
    June 2009
Posted by jimbot58 on Tuesday, November 24, 2009 2:55 AM
What you need is called a razor saw. This usually has a seperate blade and handle and the saw blade itself is very thin, the teeth on the saw range from 40-60 teeth, depending on the blade chosen. The back of the blade has a reinforcment to keep it rigid and it is very sharp. They usually have a couple of different depths available as well. Two brands I can think of off hand are Xacto (like the hobby knife) and Excel, which is usually a bit cheaper. A set would cost you maybe less than $20...
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    May 2006
Posted by aagranata on Tuesday, November 24, 2009 5:51 PM
Thanks, jimbot58.  I picked one up today at the local Michael's.  Will try it tonight....
    August 2006
Posted by HawkeyeHobbies on Tuesday, November 24, 2009 5:58 PM
Before you start slicing away with that saw. What you really need is a micro razor saw, not just a hobby razor saw. Big difference between the two.
A standard razor saw has too wide of a kerf. The width of the saws cut.
Here's what you need:
or you can chuck the blade in a #1 hobby knife handle.
This unit is from UMM-USA which is also sold by Sprue Brothers, I used to stock them but I am out.
Gerald "Hawkeye" Voigt
    June 2009
Posted by jimbot58 on Thursday, November 26, 2009 3:31 AM
I stand here with egg dripping from my face as I admit that I wasn't aware of micro saws. I always believed my razor saw was the "bomb". Forgive my improper advice....Confused [%-)]
    August 2006
Posted by HawkeyeHobbies on Thursday, November 26, 2009 7:35 AM
A micro razor saw allows you to be less invasive when cutting parts. Again the kerf of the cut is hair like thin. You can literally slice off a radiator off the bottom of a 1/48 Spit and reinstall it after insert radiator details inside. Then put it back on without any clue you removed it.
The other method you can use if you don't have a saw is to use sewing thread which I demonstrate in my post How To Cut Curves.
