BIT help
BIT help
Posted by Anonymous on Friday, January 16, 2004 3:52 AM
i bought an academy motor tool and when i opened it, the bits are not labeled... the manual is written in korean characters. i dunno what bit is for polishing, rough sanding etc... pls help and thanks!
i think the shape is standard and determines what the bit is for.
here's the picture of the bits.
www.geocities.com/garry_xxv
Posted by maddafinga on Friday, January 16, 2004 8:17 AM
Those are all grinding stones used for grinding, the various shapes are for different aplications. I use stones almost exactly like this at work. I wouldn't reccoment polishing with a motor tool anyway, unless you're polishing metal. I took a car body to work and tried it once with a real soft polishing wheel, not a good idea. Along with those stones, look into getting a metal burr or two in various sizes, and a cutting disc or two.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Buddho on Friday, January 16, 2004 8:26 PM
Garry_Gnu
Those bits will work on hard metals....soft ones like brass and aluminum will only clog the stones up quickly.
Regards, Dan
Posted by Anonymous on Friday, January 16, 2004 9:51 PM
thanks for the help!
Big Smile [:D]
