Mini-Mecca (mini-meka?) Tubing?
    October 2004
Posted by jschlechty on Tuesday, March 29, 2011 2:05 PM
I posted this in the aircraft section, but gotten no response yet, so thought I'd try it here - might be more relevant in this section.
Not sure if that is the correct spelling or not, but I remember reading that a company by that name sells small diameter tubing that can be use to replicate gun barrels, etc.
Does anybody know what size tubing I would need to replace the 20 mm cannons on a Tamiya 1/48 scale FW-190D?  I broke the plastic barrels off when I was sanding the wing joints, and would like to replace them with some metal tubing.
Also, where can one find this tubing?
Thanks!
John
    June 2010
Posted by DoogsATX on Tuesday, March 29, 2011 2:27 PM
Albion alloys makes small tubing. You can find them on Sprue Bros.
There's also the option of getting a Master armament set...
http://ultracast.ca/products/Master/48%20Scale/MAM-48-013/default.htm
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    October 2004
Posted by jschlechty on Tuesday, March 29, 2011 8:29 PM
Thanks Doogs!  As I just posted in the Aircraft section, I found them listed on the Sprue Brothers sight.  The correct spelling is "Minimeca."
THe Master barrels yo posted the pic of look like the ones on the 109E-4 I finished a while back. (Wish I'd had those to replace the plastic versions!)  The ones on the 190D are just straight looking tubes - no flare at the end of the barrel.
Thanks again for taking the time to look those up!
