My Rotary Tool
    November 2008
My Rotary Tool
Posted by Arespontus on Saturday, August 20, 2011 2:48 PM
Hello
I have a SEARS Craftsmen model number 572.248952c Rotary Tool.
It has Variable Speed with an RPM of 5000-30000
120V AC 50-60Hz
My question is is this tool overkill for sanding my models?
If you have any recommendations of rotary tools. Please let me know.
Thank-you
Scott
Posted by Don Stauffer on Sunday, August 21, 2011 11:00 AM
I do use a rotary tool (Dremel in my case) for roughing out and hollowing, especially on wood abd resin pieces.  However, for fine sanding I do it by hand.  Much safer, better results.
    February 2010
Posted by Stage_Left on Monday, August 22, 2011 11:21 AM
I agree with Don- a rotary tool (I also have a Dremel) is very handy for sanding away significant amounts of material in a short period of time. Fine sanding- filled seams, for example- yields better results if done by hand.
    February 2007
Posted by mitsdude on Monday, August 22, 2011 8:58 PM
You will not be pleased with the results if you try to use that as a sanding tool on plastics. It will eat through the plastic and probably melt some of it. Way to many RPM's.
I use one of the cheap $10 electric rotary tools combined with a dimmer switch to get the RPM's down.
I do not know if using a dimmer switch with your rotary tool will damage it.
 I also use a "Sonic Scrubber". Its basicly an electric tooth brush on steroids. I use velcro to attach sanding pads to the head of the scrubber.
Posted by Don Stauffer on Tuesday, August 23, 2011 8:47 AM
mitsdude
A good speed control is a tremendous asset. I find the latest Dremel rechargable tools have excellent speed controls as they come. I can adjust it so the shaft is turning over slow enough to count the turns!  Even for roughing out a piece of basswood or resin I never run the tool at full rpm.
    March 2008
Posted by phoneguy on Tuesday, August 23, 2011 4:57 PM
i found a battery operated fingernail polisher works.  not too many rpms and interchangable sanding tips.  just watch how much you take off at one time.
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
Welcome to Wal-Mart:  Get your stuff and get the HECK Out!
Shut up, I'll Keel U!
    February 2007
Posted by mitsdude on Saturday, August 27, 2011 11:41 AM
Don Stauffer
 mitsdude:
Don, do you have a model number on that latest rechargeable? They seem to come out with a different model several times a year. The last three versions I bought I returned after getting them home and find they had way to many RPM's. Yes, I can read the specs on the box but I have to try them anyway....just in case! Sounds like the one you have is what I have been looking for.
    November 2008
Posted by Arespontus on Saturday, August 27, 2011 1:35 PM
Hello everyone
I just wanted to thank you for your suggestions
I decided to take my time and sand with Sandpaper
I had some 320 grit  which I sanded about 5 times and then I used
some waterproof sandpaper 400 Super fine grit.
I have to say it looks very good.
My Patients paid off. I may try a rotary (dremel) tool in the future but for now I think I'll stick to
the Sand paper.
Thanks
Scott
