There are several commercial aircleaners out there that pretty much match what you want. However be prepared for sticker shock - for the price you pay, you could buy a pretty good aircompressor and an airbrush.
You said you model in the basement. Is there a window near your modeling area that you can easily open and close when you want to? If you do, take its inside measurements, go the Lowe's or Home Depot and check out their window fans. They should have one which will fit (or fit with minor modifications) that can be easily installed and removed each time you go modeling. And shouldn't cost too much.
