And with soldering, "Cleanliness is next to Godliness" is the thing to remember. You can not get things to clean. Use fine solder that has a resin core - DO NOT use an acid core or flux for PE or Electronic soldering.
Use an alcohol swab just prior to applying heat, and use glove to keep your finger oils & acids off the parts.
Reid
