for xmas received SOYA soft metal kit (hasegawa). Can I use TESTORS enamel brush on ( I dont have air brush ) and what cement should I use. Just got back to modeling after many years and have only worked on a few plastic.kits. live in small apt.but might try spray can if ok to use on metal.
happy holiday and thanks tom
Super glue for assembly. Prime then paint with paint of your choice.
Gerald "Hawkeye" Voigt
You must use primer before painting metal. Once primed, you can paint with anything you normally do. Good primers to use on metal include Krylon, Duplicolor or any primer intended for full sized car painting.
For gluing use either CA or epoxy.
