Graduated disposable syringes, usually 1ml & occasionally 5ml for overall colour coats, I use mainly acrylics so cleaning isn't a problem - a couple of pumps with water & their clean.
When I say syringes, these things are usually called "oral dispensers" or "Enteral dispensers", they are readily available at pharmacies & generally used to give reluctant babies / children medicine. Some brands are not so good as the plunger seal will swell even with alcohol, but others are fine. I'm not if the sure if they are available in the US, but the Baxa ExactaMed range works well for acrylics & enamels, they also tend to last far longer than disposable pipettes;
