Anyone use Weld-On 4 for assembly?
    August 2011
Posted by GreenThumb on Friday, January 18, 2013 7:03 PM
I am out of Tenax 7R and I thought I saw someone on a forum say that the Weld-On 4 was great and cheap when you buy it in bulk at places like TAP Plastics we have here. They have the 4 oz. bottle for $9 and a pint for $17. Much cheaper than those 1 oz. bottles of Tenax 7R.
    August 2011
Posted by GreenThumb on Friday, January 18, 2013 11:47 PM
Sorry, that should have read Weld-On 3
    December 2006
Posted by Jester75 on Friday, January 18, 2013 11:48 PM
I have. Seems to work as well as any other liquid cement since I believe its the same thing, MEK.
Eric
    August 2011
Posted by GreenThumb on Saturday, January 19, 2013 4:00 PM
Thanks Eric. If they contain MEK why don't people just use MEK which can be found at any hardware store? Is straight MEK too hot? It looks like from the MSDS sheet on IPS' website the Weld-On 3 is 65% MEK and 10% Acetone so I wonder if the other 25% is something that makes it less aggressive?
    December 2006
Posted by Jester75 on Saturday, January 19, 2013 4:14 PM
Not really sure Mike but if you do use Weld-On, make sure you take the precautionary measures as from what I've heard it is some very nasty stuff to inhale or get on your skin. I used to use it all the time to build acrylic aquariums but always used it in an open garage.
Eric
    April 2009
Posted by Cadet Chuck on Saturday, January 19, 2013 9:22 PM
MEK is nasty stuff, so be sure to wear a vapor respirator if you are using it.  I have found it has been pulled from the shelves in all the hardware stores around here (Colorado) and suspect it is another crusade by the "Green Wienies" who seem to have made this state their HQ.  Now I can only find "MEK Substitute" and I have no idea what it is.
    August 2011
Posted by GreenThumb on Sunday, January 20, 2013 12:10 AM
From what I have read in researching it Chuck it seems the chemicals in Weld-On 3 and Tenax are arguably worse than MEK. Interesting.
    October 2008
Posted by Lacquer Head on Sunday, January 20, 2013 7:54 PM
If Tenax 7R is your favorite poison, then off the shelf, Weld-On 3 is your best bet.
Most of the plastic welders are MEK, Acetone, Butyl Acetate, Methylene Chloride or a combination of same. MEK is probably the safest, but don't drink it. LOL!
I stopped chasing the dragon and now use a custom blend of 60% MEK, 30% Acetone and 10% Ethyl Alcohol. It's fast, cheap and will melt most plastics that I have come across in modeling.
Most Lacquer Thinners are nothing more than blends of MEK and Acetone.
Congrats on your son making D.I. I bet your one PROUD POPPA!
NOW FINISH THAT LAV!!!
"Lacquer Head feeds his one desire, Lacquer Head sets his brain on fire."
    August 2011
Posted by GreenThumb on Sunday, January 20, 2013 11:23 PM
Thanks LH and yes I am very proud of my soon to be USMC Drill Instructor son.  I think I will try some Weld-On 3 since from what I understand MEK is becoming real hard to find these days. I have a gallon of lacquer thinner in the garage as well and just gave that a try. It doesn't work that well.
Guess I will get the Weld-On #3
    February 2008
Posted by yeagermister on Friday, March 29, 2013 9:57 AM
Yes I'm using it but its not the same at all.
    September 2010
Posted by NervousEnergy on Wednesday, April 24, 2013 2:22 PM
I've used a lot of Weld-On 3, but you've got to be careful with it.  It's a lot hotter than Tenax.  From mixing and matching solvents over the last few models I've come to the conclusion that Tamiya Extra Thin is within a hairs breath of Tenax in terms of heat, and that WO-3 is nearly twice as hot as either.
I now only use the WO3 for big joins like wing roots or fuselage halves when I can put the stuff down from inside.  For surface capilary action joins I much prefer Tamiya or Tenax.
    May 2003
Posted by qmiester on Sunday, April 28, 2013 7:53 AM
Check at TAP and see if they still carry Methylene Chloride.  I've used it for years and I do believe that its is the exact same thing as Weld-On 3 (in fact I use two old Weld-On 3 bottles I fill w/the Methylene Chloride for use at my modeling desk).  At one time you could get it in gallon cans (lasted 3-5 years) and was a heck of a lot cheaper than the Weld-On 3.
Quincy
    January 2011
Posted by stymye on Thursday, May 9, 2013 4:26 PM
...right ..ok...did you read the post?  ... weld-on 3 is 65 % MEK ....10% actetone... it is stated plainly on their website.
 here's a break down of some popular cements.
*Testor's liquid (glass bottle) = MEK + ethyl acetate
*Ambroid, pro weld = methylene chloride
*Tenax = Butyl Acetate
*Weld-on  ( styrene effective products from them) = MEK  + acetone
    June 2013
Posted by Reaper420 on Sunday, June 16, 2013 12:51 PM
Never tried it on models myself. I also used to use it for building acrylic aquariums. Be careful with how you apply it as its a solvent cement meaning it slightly melts the plastic. It melts the two halves together and joins em that way. If you get any on an area that its not supposed to be on get it off quick because like I said it starts to melt and soften the plastic immediately. And when you do remove try not to wipe but dab it off. Wipping it across will leave an unsightly scar in your plastic
Kick the tires and light the fires!
