in addition to what everyone else said put tape as close to the seam as possible on both sides, add putty pull off tape while the putty is still soft and knock down the ridge with solvent (i use 3m red bondo and acetone/nail polish remover). you can retape on eithet dife before sanding and keep replacing the "protective " tape as it wears.
a while back someone said they use the expanding gorilla glue for wing roots. it foams up as it dries leaving a ridge that can be scraped off.
if the gap isn't huge white glue might work too. i use it a lot for small seams in hard to reach places.
