Blue Tack works well, and it's a high tack. I haven't had it lift paint, but I think I've been lucky. It can also be a little tough to shape perfectly. Silly putty also works well, but doesn't have the same rigidity to it, and is easy to 'smear' out of shape. It's also hard to cut to a hard line. Personally, I just use de-tacked Tamiya tape. I cut to the shape I want, stick it to myself several times (the wrist, palm of the hand, forehead work well) and then apply to the area I want to mask. It stays in place, but doesn't lift paint. I'd also highly recommend sealing any masking edge before you start working on it, saves touch ups and bleeding. To seal the edge, you want to paint your previous color over the mask (lets say it's a white plane and you're masking and painting black, lay in your mask, do a thin layer of white and let it dry. Then come back and paint your black, no bleed as the white has dried onto the edge of your mask, and if it bled, you won't notice it).
