Cynoacrilate question
    February 2011
Posted by Raualduke on Sunday, October 27, 2013 9:20 AM
Will keeping cynoacrilate in the refrigerator extend shelf life? Are there other ways to extend shelf life?
    September 2005
Posted by Sprue-ce Goose on Sunday, October 27, 2013 9:36 AM
I keep it in the refrigerator sealed in an airtight container.
The cold may help reduce volatility, but sealing the container from oxygen most likely does more to preserve it.
Posted by gregbale on Sunday, October 27, 2013 9:47 AM
Lower temperature does indeed extend the working life of CA, and the airtight container helps as well. But the greatest enemy of CA "in the tube" is moisture. Fridges tend to be a pretty high-humidity environment, so proper sealing of the container is the key.
Greg
George Lewis:
    February 2011
Posted by Raualduke on Sunday, October 27, 2013 10:04 AM
Thank you both for your replys,
Posted by Don Stauffer on Sunday, October 27, 2013 11:50 AM
The limited shelf life is the reason I buy only the smallest containers of the stuff. I know that it is cheaper per ounce in a larger container, but if half of it hardens in the container it is no bargain.
    February 2011
Posted by Raualduke on Sunday, October 27, 2013 12:23 PM
Yep,I just tossed three of the big ones,all hard as a rock.
    April 2006
Posted by jgeratic on Sunday, October 27, 2013 10:28 PM
Another key when using it is to place a dab on some throw away surface, instead of applying it directly from the bottle.  This way you can cap it right away, and only the excess you squeezed out that isn't used is thrown away.  I'm using one of those Zap products, bottle is half empty and still good.  It has both a needle plug cap and a cover that doesn't come in contact with the glue - this really helps in keeping the integrity of the seal.
regards,
Jack
Posted by Don Stauffer on Tuesday, October 29, 2013 9:10 AM
I use old business cards for that.  For gel CA either glossy or matt cards work.  For the regular CA, I find it absorbs into the card and I waste a lot, so I save the glossy cards for the regular CA (I use far more gel stuff to get the slower setting time). I keep CA accelerator handy in case I want to speed things up when I get everything in perfect position.
    February 2011
Posted by Raualduke on Tuesday, October 29, 2013 10:40 AM
Thanks don,I've been using old business cards for quite a while now. It only absorbs on the first go around,then kinda seals itself off .I'll often have two viscositys of  cyno puddled depending on what I'm doing.cards also are great for painting figures with vallejo
    August 2009
Posted by JOE RIX on Thursday, October 31, 2013 4:31 PM
Another option you may want to consider is to get Gorilla Glue Super Glue. Not so much for the quality of the glue but rather for the design of their container. It is specifically designed to maintain the life of the glue. I have had a container for 5+yrs that just sits on my desk and the glue inside is as good as new.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    September 2012
Posted by GMorrison on Thursday, October 31, 2013 4:48 PM
jgeratic
regards,
Jack
YThats what I do. I put some on a piece of masking tape stuck to the bench top. It isnt absorbed, and peeling it up to throw away is simple.
    February 2011
Posted by Raualduke on Thursday, October 31, 2013 8:32 PM
Thanks to all for your input
