Holes for gun ports?
Posted by Anonymous on Thursday, March 4, 2004 9:09 AM
I am currently finishing an old Monogram F4f Wildcat, has no gun ports!! any sugestions????? (no I dont have a dremel drill) thanks jj
    May 2003
Posted by qmiester on Friday, March 5, 2004 9:59 PM
I wouldn't reccommend a Dremel any way, doesn't drill through plastic rather melts its way through. I have a pair of pin vises, which will accomadate 1/8th thru #80 drill bits and hand drill the holes I need in plastic.
You figure out what size hole you need, select the size bit to use (sometimes a cheap dial caliper helps) and drill the hole. If you are drilling into a rounded plastic surface, start by spinning an exacto knife with a #11 blade at the exact location you want the hole. This will keep the drill bit from slipping away from where you really want it. I would reccommend that, if you have one available, use an old model to practice on.
Quincy
Posted by Anonymous on Sunday, March 7, 2004 12:17 AM
Thanks a lot Quincy for your suggestion.............Jorge
    September 2011
Posted by fightnjoe on Sunday, March 7, 2004 9:59 AM
wow doing the same kit. hadnt got that far yet. hadnt noticed the lack of gun ports.
joe
Veterans,
Thank You For Your Sacrifices,
Never To Be Forgotten
Where you can find me:
Workbench on FaceBook  Google Plus  YouTube
