What glue is impervious to lacquer thinner?
    December 2011
Posted by Chrisk-k on Monday, March 30, 2015 6:03 PM
It seems lacquer thinner can remove CA.  What glue is impervious to lacquer thinner?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    February 2014
Posted by CN Spots on Monday, March 30, 2015 11:50 PM
Plastic resin glue is "resistant" to lacquer thinner but not impervious.  I doubt any adhesive can stand up to it for long.
MEK melts the plastic pieces together so technically there's no glue to be destroyed by lacquer thinner.
Posted by Don Stauffer on Tuesday, March 31, 2015 8:50 AM
There are primers that withstand lacquer, so priming a completed model is one way to paint with lacquer.  Also, I find a hot lacquer usually affects the styrene if the model before it affects the glue.
    December 2011
Posted by Chrisk-k on Tuesday, March 31, 2015 12:26 PM
I'm trying to glue the tip of an interdental brush to a syringe needle to make an airbrush cleaner that can easily go inside an airbrush (Don's airbrush article mentions this).
I'll use lacquer thinner to clean my ABs and I don't want the tip of an interdental brush to fall off inside my ABs!
Because the amount of lacquer thinner needed to clean ABs is very small, I guess it's OK to use CA, but I'm not 100% sure.
    August 2014
Posted by goldhammer on Tuesday, March 31, 2015 1:01 PM
Epoxy might hold up a little better than CA for the time in thinner.
Posted by Don Stauffer on Wednesday, April 1, 2015 9:09 AM
Anyone know what CA debonder is (chemical)?
    October 2008
Posted by P mitch on Wednesday, April 1, 2015 9:35 AM
nitromethane, dimethyl sulfoxide, and methylene chloride all have an effect. Acetone (nail varnish remover) works well and is cheaper/easier to get hold of with out a licence
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    May 2008
Posted by ejhammer on Wednesday, April 1, 2015 9:40 AM
MSDS says Dimethylformamide, whatever that is.
EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
