WIP:Academy F-18 (1/72)
On Deck
MH-60G 1:48 (Minicraft)
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Ting Ting Ting, WTF is that....
Seam ripper? Never heard of that one. I'm assuming you meant Panel Scriber like this:
www.micromark.com/panel-scriber-for-plastic-models,7194.html
BlackSheepTwoOneFour Seam ripper? Never heard of that one. I'm assuming you meant Panel Scriber like this: www.micromark.com/panel-scriber-for-plastic-models,7194.html
I might have to try it out on some spare parts and compare them from the one I use now.
Use a Panel Scriber, or a Tamiya/Olfa P-cutter, or a needle in a pin vice.
Using a sewing seam-ripper would, just skip & wander off-line, or just dig trenches, as the tip isn't really sharp enough to use without some force.
East Mids Model Club 32nd Annual Show 2nd April 2023
http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
The seam ripper that my wife has would have to be held almost parallel to the surface to scribe a line. That seems like it would be hard. Also, the shape has no surface parallel to its axis that is straight enough to hold against a ruler.
For creating panel lines I have used Tamiya's Scriber and a METAL straight edge (Dont use a plastic ruler. How do I know? Yeah..... lol). You have to start really light though and make many passes. Works great though.
Boeing Build - June 15 2015 Mustang Build - Feb 1 2015 Artillery Build - April 16 2015
Hi;
Everyone is going to say Oh Gee he's real old school . I don't own a panel scriber anymore ( broke the tip while working on a model .) I now use a Number 11 blade backwards in the groove after I file the end smooth .
This worked before the scriber and still works now . I use Label Maker Embossing tape for my guides .Works okay for me ! The biggest thing to remember is , a gentle touch works best !
