WIP:Academy F-18 (1/72)
On Deck
MH-60G 1:48 (Minicraft)
C-17 1/144
KC-135R 1/144
Academy F-18(1/72)
Ting Ting Ting, WTF is that....
Do you mean something like these?:
www.harborfreight.com/6-pc-fine-point-tweezer-set-93598.html
Yup - I got'em.
Look:
www.micromark.com/flat-and-smooth-decal-tweezer,7279.html
Very similar to what you're looking for...
Go to Micromark.com and do a search for tweezers. You will find what you're looking for.
I have a few pair of these cheap, angled tweezers. I bend the prongs inward, and they work great for holding wheels while you're airbrushing them and letting them dry.
--Rob
Glue Sniffer since 1977
Although rather pricey, this place has nearly every type of tweezer in the known universe:
http://www.techni-tool.com/categories/Precision-Tweezers
I want a pair of hard rubber tipped tweezers. I can't find any but I think having the rubber would prevent parts shooting out across the room. Do these exist?
Dolphin
buy a set of cheap tweezers and use Liquid Electrical Tape http://www.ebay.co.uk/itm/New-Liquid-Electrical-Tape-for-Boats-SCP-14201-/331150272304?hash=item4d1a182730:m:mABMKhbrXDI82toFgefl8BA
Just dip them in and leave to dry. The idea was in FSM a few months back and they work great
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
Dolphin24 I want a pair of hard rubber tipped tweezers. I can't find any but I think having the rubber would prevent parts shooting out across the room. Do these exist?
Just curious.... I am a newbie and reading and learning.
So what would you use these for? Thanks
[quote user="Kardar2"]
I am new thanks for the idea
in theory they would be for anything, mainly small, rounded parts that metal tweezers sometimes won't hold very well.
oh cool, I might need to try that
USAFASME7 I have a few pair of these cheap, angled tweezers. I bend the prongs inward, and they work great for holding wheels while you're airbrushing them and letting them dry.
I just use a toothpick.
GreenThumb USAFASME7 I have a few pair of these cheap, angled tweezers. I bend the prongs inward, and they work great for holding wheels while you're airbrushing them and letting them dry. I just use a toothpick.
Me too, held in a wooden clothespin. Just snug that toothpick into the wheel real good and tight, should be good to go.
Gary
"All you mugs need to get busy building, and post pics!"
Jamming a toothpick into the axle hole is also convenient for hand painting wheels. You can slowly twirl it while holding a small paintbrush against the rim. Since you do not need to move the brush with your hand/fingers, you can brace them and get a nice good line of paint that way.
Yep Don, been there too. That works quite well with a bit o' practice.
The only solution I have found to avoid tweezers to cause tiny parts to launch to parts never-again-to-be-found is to avoid using tweezers for tiny parts.
