UV activated "Lazer Bond' glue
    April 2005
Posted by wing_nut on Thursday, February 11, 2016 12:39 PM
I don't know if this stuff has been discussed here or not.  Lately there have been a few infomercials about this stuff, or similar, and it looked like there may have been modeling applications.  I picked up some At Bed, Bath and Beyond to do a couple of tests.
The sprue gates for the Stearman I am working on are on the large side and I didn't do a very good job getting them off.  there were 2 that lined about the there was a sort of pitted surface after a light sanding.  A drop of the liquid glue and 20 seconds with the UV light and it was hard.  The product said 8-10 seconds but it's not enough, at least with this brand.  Sanded out great, really smooth.
Then I starting thinking about PE and how strong the bond would be on a small footprint.  A tiny piece of fret was bent 90 degrees and bonded to the inside the Stearman wing. The pre-cured glue is just viscous enough to hold the part standing on its own.  Something being bonded to a vertical surface will likely need to be held unless it's really small. After curing it holds the full weight of the wing upper half with a pretty uneven weight distribution putting some good torsional stress.  Looks darn strong to me.
Marc
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, February 11, 2016 12:57 PM
Interesting. What is the product called at Bed Bath & Beyond? Gotta check it out.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, February 11, 2016 12:58 PM
I wonder what kind of reaction it would cause using on clear parts? Sometimes those itty bitty HUD clear parts fall off easy.
    August 2008
Posted by tankerbuilder on Thursday, February 11, 2016 1:11 PM
Hi ;
 Hey , I bought one of those advertised on the Telly .Wow ! Sure does a good job on warped hulls . Hold it straight , Put a drop on the ends and hit it with the light .Viola ! A straight ship hull .
  I like this stuff .I think it will be great for P.E.    T.B.
    January 2013
Posted by jibber on Thursday, February 11, 2016 1:12 PM
Do you know how much product it holds and hows the price? Everytime I see those commercials I think of ordering but BB&B may be a better option because of their discount.
Thanks for the review.
Terry
    January 2014
Posted by gobobbie on Thursday, February 11, 2016 1:27 PM
One nice thing if you go to bed bath and beyond there is always coupons available. Bob Gregory Ruining one kit at a time
    September 2005
Posted by Sprue-ce Goose on Thursday, February 11, 2016 1:37 PM
Thanks for posting about this.
I don't like ordering from info-mercials so it is good to hear the product is available at Bed Bath and Beyond.
Will check for another one of their coupon flyers in my mail Big Smile
    April 2005
Posted by wing_nut on Thursday, February 11, 2016 1:57 PM
Black Sheep, here's a pic of 2 pieces of clear sprue I just bonded.  No adverse affects so far.  This will be good for attached canopies.  The pre-cured stuff can be cleaned away if need be before the bond for a nice clean job.
The product is called Lazer Bond. $10 at BB&B.  But if you're like us, we have a drawer full of the 20% off coupons at any given time.  The tube dimensions are 2" x 3/3'.  It doesn't give a quantity but it looks like a pretty decent amount considering how much is used.
Marc
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, February 11, 2016 2:38 PM
I'm sold! The missus has a whole mess of BB&B coupons anyways.
    January 2014
Posted by Silver on Thursday, February 11, 2016 7:10 PM
Later Bond out performs any super glue types of cement .I completed a whole detail 1/48 scale F-16 by Lazer bond.It wet sands great,and works good for strong 1:32 scale types of models.Its the wave of future modeling.You can complete a model in 1/2 of the time.Good for well fitted models like Tamyia, Hasegawa,and so on.
    January 2014
Posted by Silver on Thursday, February 11, 2016 8:14 PM
    January 2014
Posted by Silver on Thursday, February 11, 2016 9:51 PM
Keep in mind that this Lazer glue system is not new.Other products have been out there for about ten years.
    August 2013
Posted by Jay Jay on Friday, February 12, 2016 8:44 AM
I saw this stuff on TV and was dubios, as I am with all infomercials, but I bought it anyway because I thought it might work on canopies and clear parts.
It works great on canopies !  If there is a slight misfit gap between the canopy and fsg. it will fill it absolutely clear. You can easily wipe off any excess glue that happens to get in an unwanted place before hitting it with the light.  I have also used it to make the small side aircraft windows and it is instant, No waiting for the windows to dry overnight like the Testor's window maker glue. It sets stronger than Elmer's white glue or "the Detailer" glue that I have been using for clear parts too.
The firtst thing I tried to glue was a small piece of PE onto the inside of a clear canopy and it was very good for that purpose as well. Very nice to have a product that does what it says it will do.
Posted by Don Stauffer on Friday, February 12, 2016 9:22 AM
My dentist uses something like this for fillings, or for repair of fillings.
The stuff I see on TV includes both the laser and the glue in each package, making it a bit expensive.  Can you buy just the glue, so you buy the laser once, but can keep buying more glue without buying a new laser?
BTW, I am wondering if it is really a laser vs a UV LED.
    May 2008
Posted by ejhammer on Friday, February 12, 2016 12:22 PM
Just picked one up today to test out. Says on the package - "clear liquid plastic - hardens with UV light". Is a modified acrylamide and mixed acrylates. Warning label says - "Liquid causes serious eye damage. Eye, skin and respiratory irritant. Do not breathe vapor. Keep away from heat and flames. UV light can burn eyes and skin. Do not point at people or animals. Keep away from children, Prevent contact with eyes, skin and clothing".
Seems some care in use is appropriate, just like using other adhesives, paints, thinners etc. I myself will sometimes get a reaction to CA glue when using lots of it in building wood models. I get symptoms just like a cold, although an allergy pill relieves the symptoms quickly.
Gonna test it on plastic and wood tomorrow, report to follow.
EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    February 2016
Posted by SilenceDeuxgood on Friday, February 12, 2016 3:54 PM
ejhammer
EJ
EJ,
Saw that UV kit on the TV and thought about the usage for building. Please let us know how it goes, would like to see before i consider purchasing it.
Thanks,
S. Deuxgood
OTB: 1/32 P-47D #228382, 1/24 AMG GT3 "Battlefield 1",
"Semper en Hostes"
"Ne Desit Virtus"
    September 2005
Posted by Sprue-ce Goose on Friday, February 12, 2016 9:39 PM
Don Stauffer
Looks like a UV LED to me .............
"giggling " UV cure glue comes up with other brands and I ought to still have a small UV lamp left over from my Gilbert brand childhood chemistry set Hmm
Posted by Texgunner on Saturday, February 13, 2016 8:10 AM
I guess I could hold one of my four foot black lights up to the job, eh?   I have one that is never turned off, well, seldom that is.  I bought it in 1972 and it's still going strong.  It stands in a corner of our kitchen.Big Smile
Get you one of these and recall your "wasted" youth! Wink
"All you mugs need to get busy building, and post pics!"
    May 2008
Posted by ejhammer on Saturday, February 13, 2016 10:27 AM
Ran my tests.
The kit looks like this and has a metal dispensing tip somewhat larger than the tip on Model Master liquid cement bottle.
I snipped off two pieces of grey spru. Did not sand or dress the ends.
Applied a bit of the glue. It is about like thick CA in consistancy. Used the UV light for a few seconds.
Added some weight for a durability test. For a butt joint, it seems pretty strong.
Next some clear spru. The glue is clear as well. The glue solidifies to a kinda tough plastic. Seems to be slightly flexible. As in a previous post, it did not craze the plastic.
Next, two pieces of strip styrene. I found I needed to sand the surface slightly on this to get it to stick. Not sure if this is because of some surface contamination or if regular moulded styrene from a kit would be the same.
Deliberatly left a gap to test filling properties.
The gap filled and sanded. Came out very smooth, although the glue sands a bit tougher than the styrene strip.
Next - wood. Basswood strips.
Glued the joint. It is a small joint and in shear. The weight bent the wood but the joint held well.
Last, some PE. My Achilles heel is PE railing. I put an elongated puddle of glue on my glass work surface. Then with tweezers, dipped the edge of the pe railing (1/700) in the glue, held it on the previously tested styrene strips and used the light. In just a few seconds it was stuck. I ticked it with my finger tip to see how well it held. The rail bent, but did not come loose from the styrene.
I can see that adding this stuff to my arsenal of adhesives might prove an advantage. I don't know how much glue is in the dispenser and it doesn't say on the package. At $9.99 it seems a bit pricy, but then, CA isn't really cheap either, especially since it seems my CA seems to go bad before it's all used anyway.
Was an interesting experiment.
EJ
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, February 13, 2016 4:03 PM
Thank you for the insight and experiments, ejhammer. Very interesting indeed. I'm sold.
