Handy Disposable CA Applicators
    April 2012
Posted by Striker8241 on Wednesday, March 9, 2016 8:18 PM
I've discovered that those plastic toothpicks that are so much better for your teeth are also handy CA applicators. The CA won't stick to the plastic - just clean it off the end. You can also shape or trim the tip. When they're worn out, just throw them away. Below is one brand available.
    July 2013
Posted by modelmaker66 on Thursday, March 10, 2016 12:11 AM
Thats a great find! Thanks! Ive been tring the photo etch type that you use with a hobby knife handle. Not too great. I hope these are better.
    January 2016
Posted by Sailor Steve on Thursday, March 10, 2016 8:59 AM
I've been using thin pieces of brass wire, with mixed results. Count me as another one who'll be giving these a try.
Posted by Don Stauffer on Friday, March 11, 2016 9:01 AM
I use a large needle shoved into a length of 3/8 inch dowel. I cut the eye in half with Dremel and abrasive disk, leaving a small fork.  Needles are made from a hard stainless steel, so you can cut away any CA deposits and the tool will last a long time.
I use another identical tool to apply spots of CA accelerator.
    September 2009
Posted by Cobra 427 on Friday, March 11, 2016 1:17 PM
Here's a novel idea: Try going to your local music store and get a guitar string - the plain unwound ones work best. You can either glue it to the top half of the tube around the opening, or tape it in place. This makes a tiny thin wire line that you can use for the glue to run along so that you don't get a giant drop of glue where you don't want it to be. You can probably use jewelers' wire, but it won't come in such a small size. You can use T shaped pins to seal your glue bottle shut. It helps to keep the tip from becoming clogged, and it will also make an easier time to clean it up when you need to. I've done this for over twenty years when I need a part touch up, or one that breaks loose, and I don't want to repaint because of a tiny glue droplet.
~ Cobra Chris
Maybe a picture of a squirrel playing a harmonica will make you feel better?
    July 2013
Posted by modelmaker66 on Monday, March 14, 2016 12:10 AM
thanks for the help. its a lot more economical than a fancy applicator thing! Does the t hspe work better than a standard pin? Ill try. Thank you.
    April 2008
Posted by spiralcity on Monday, March 14, 2016 1:34 AM
I have been using scaps of wire for years and it seems to do the job just fine. I'm glad you found something that works well for you. Thanks for sharing the idea.
    April 2012
Posted by Striker8241 on Monday, March 14, 2016 8:28 AM
Don Stauffer
Hi, Don,
Thanks, that's a great idea, especially for precise applications.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Monday, March 14, 2016 8:30 AM
Cobra 427
~ Cobra Chris
Hi, Chris,
A great idea as well!
Cheers,
Russ
    January 2014
Posted by gobobbie on Tuesday, March 15, 2016 11:29 AM
Anyone looking for the plastic toothpick applicators, they are available at that Mecca of modeling supplies, the dollar store. Bob Gregory Ruining one lit at a time.
    August 2016
Posted by scaler on Tuesday, October 18, 2016 3:31 PM
I've been using a 0.5 mm mechanical pencil for CA application. Once I'm done, I just break away the used portion of the lead and extend a new length of it. Very quick, economical, and there is nothing to wipe. Smile
Also, search for "microbrush" on eBay. Those tiny applicators have numerous uses in modeling. You can find them for about $2.00-2.50 per a pack of 100, incl. shipping. I think the purple ones are the thinnest. Here is an example:
http://www.ebay.com/itm/100PCS-Disposable-Eyelash-Extension-Micro-Brush-Applicators-Mascara-Wands-Tools-/272266528193
Hobby stores sell those, too, but they charge considerably more.
Some think this is actually fun!
    March 2016
Posted by ardvark002 on Wednesday, October 19, 2016 7:42 PM
thanks for the tip, will try. regular toothpicks work well.
    February 2007
Posted by mitsdude on Thursday, October 20, 2016 12:08 AM
scaler
I have these. Lots of uses. For about $10 delivered you can get 100 of each color. Should last a looooooooooooooooong time.
