Palette Knives
    August 2014
Palette Knives
Posted by goldhammer on Saturday, August 27, 2016 9:47 AM
Was in the local Wally World last night and found a bag of 5 plastic palette knives for just under $3.  Picked them up for application of filler.  Lot less expensive than the metal versions, and can be shaped to whatever you need fairly easily.  Were in the art/craft section.
Posted by Don Stauffer on Sunday, August 28, 2016 11:06 AM
My pallette knife is my goto for filler application.  However, I use a wooden handle- stainless steel blade version.  The stainless blade means I can clean off any residual putty left on the blade with no problem.  I can also wipe blade with lacquer thinner to clean it after I am done applying putty.
    August 2014
Posted by goldhammer on Sunday, August 28, 2016 11:52 AM
I just hit these with some laquer thinner and it didn't affect them.  Easy to cut to specific shape with a razor blade of # 11 blade.  Only issue is they are a little flexible when cut to a narrow point, but that can be an advantage in some spots.
Next time I get over to HL I want to take a look at what they have in the metal versions.
    June 2014
Posted by Tanker - Builder on Sunday, August 28, 2016 4:51 PM
Hi;
    If you've ever seen the assortment of trowels a brick-mason uses , you will find a lot of palette knives in those shapes .The one that is my go to for tight spots is shaped like a cake trowel . I will check more , I just returned from my local Hobby - Lobby .
    They have nine different shapes , both in long and short blade surfaces .The thing is , wether filling cement join gaps , or preparing a surface for new panel lines , these can be helpful in many applications .
    Another simple applicator , believe it or not is the ubiquitus plastic knife you get at a burger joint . File off the teeth and it's perfect for doing wing fillets ! T.B.
    September 2006
Posted by the Baron on Tuesday, August 30, 2016 11:39 AM
I've got some dental putty spatulas that I use.  As Don points out, they can be cleaned up with strong solvents.
I also have made my own, with plastic table knives.  Similar to what TB described, I filed off some of the teeth, for a straight edge.  I also squared off the tip, and I left some teeth on the curved side, for carving ridges in putty (eg, making Zimmerit).
    June 2014
Posted by Tanker - Builder on Wednesday, August 31, 2016 4:42 PM
Hey Baron !
 Did you peek at my old train building book ? That's how I used to create fluted sides on passenger cars , way back when .  T.B.       Yeah , I did Zimmerit with it too .
