Optivisor Recommendations
Posted by Tojo72 on Friday, November 18, 2016 1:59 AM
Looking for some suggestions,like model numbers or links.I want to use them on painting 1/35 figures mainly and some 1/48 cockpits,I do not need glasses for reading or close work,but can' help but think that the optivisor could be helpful for painting.Don't want to spend a ton.
thanks
    November 2003
Posted by mississippivol on Friday, November 18, 2016 7:22 AM
Got a different brand at the local art/craft store. Works well for me though you have to sneak up on the part to get it in focus.
Posted by gregbale on Friday, November 18, 2016 8:30 AM
I picked up a cheap knock-off version at Harbor Freight and have been totally happy with it (going on 2 yrs. now). Item #38896, currently listing for five bucks. Link here
Greg
George Lewis:
Posted by Don Stauffer on Friday, November 18, 2016 9:35 AM
If you don't need glasses ordinarily, cheap reading glasses may work fine.  We have dollar stores around here that have such glasses at a buck apiece, and places like Walmart have them for around five bucks.  Try some on with about half to one diopter.  The fancy optivisor types are very high magnification.  Once you get to high magification the prisms in those fancy ones prevent eyestrain. If you go above about two diopters with reading glasses you may get headaches if you use them for a long time without breaks, but if you don't ordinarily require reading glasses lower diopters may work fine for you, and the reading glasses will be cheaper and less junk on your head.
    May 2013
Posted by hogfanfs on Friday, November 18, 2016 1:01 PM
I find glasses to be easier to use than an Optivisor. I purchased a pair of +5.00 and a another pair of +6.00 reading glasses off Amazon for $9 each. I don't use them for long periods of time, but, they are very helpful in seeing small details. And best of all, I look like a complete nerd.Big Smile
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    November 2008
Posted by plasticjunkie on Friday, November 18, 2016 1:08 PM
gregbale
Ditto. I've been using the same one from HF for almost 5 years and bought another as spare. I started with the 3 and 4x glasses but find the HF product better to use.
 GIFMaker.org_jy_Ayj_O
    July 2006
Posted by Gymbo-59 on Tuesday, February 28, 2017 11:29 AM
plasticjunkie
gregbale
My girlfriend gave me a pair for Christmas 2 years ago.  There also good for other uses around the house where a little extra light is needed & you need both hands.
Duct tape is like the force.  It has a dark side & light side and it holds the universe together.
    March 2013
Posted by patrick206 on Tuesday, February 28, 2017 4:13 PM
About 40 years ago, well before I needed glasses, I bought the Optivisor with #4 marked in a corner. Worked extremely well for close up details, but didn't need them often.
Then, at age 45, I suddenly realized that print and model details had become much smaller. (:>) So I went with gradually stronger reading glasses, finding them to be almost as useful as the original strength Optivisor, at last check I could double up the readers if needed, combination of 2.75 and 3.75 worked great.
Now if working really close I can use the 2.75 correction readers, combined with the new #7 Optivisor, looks awful but effective. Like the others, if you can find a reader set from the El Cheapo store, (where I bought mine,) I'd surely recommend that over the Optivisor. $1-$5 is a lot better than the $60 plus Optivisor. It the readers work for you, great, otherwise try the HF model.
The only thing really measurable in effectivenss, is the clearly superior optical quality of the Optivisor. They are really good, but don't buy them unless you find them to be notably better.
This hobby shouldn't break the piggy bank.
Patrick
