needle files
    March 2016
needle files
Posted by ardvark002 on Monday, November 21, 2016 10:09 PM
Hi, Its me again , hope your all good. My question is,what's the best way to remove buildup, plastic, primer etc, from needle files?  Wire brushes, solvents?  Suggestions I would realy like.  Thnxs Aardvark
    July 2004
Posted by stikpusher on Monday, November 21, 2016 10:51 PM
i use brushes to clean mine. Old toothbrushes or something similar works just fine to get out the dust residue. Solvents run the risk of turning styrene dust into goo and making it harder to remove.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2004
Posted by Jon_a_its on Tuesday, November 22, 2016 3:58 AM
A fine brass wire brush, such as is sold for cleaning suede, and a fine needle tip, the shaft sunk into a dowel for the picky pits.
Keep them clean & dry, & dust with talc after use, & they will last, mine are 25 years old.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Don Stauffer on Tuesday, November 22, 2016 9:38 AM
I second the brass brush.  That is my go-to method.  Now, that does not work forever.  Needle file sets do need to be replentished periodically, but they are not that expensive.  I am lucky and have a Harbor Freight store not too far from me. They sell them.
Small files are my normal seam cleanup tool.  I find they take off material faster, yet leave finer scratches, than sandpaper.  I find a single coat of a good primer covers the fine scratches well enough.
    January 2006
Posted by dirkpitt77 on Wednesday, November 23, 2016 3:17 PM
I didn't have any input. I just wanted to say this was a great question! I only have a couple files that I don't use nearly as much as I probably should. One is broken in half. Maybe I should pick up a new set.
--Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    October 2007
Posted by Milairjunkie on Thursday, November 24, 2016 6:00 PM
I'll 3rd the brass shoe / spark plug brush - ideal for files & tools in general such as caked screwdriver tips or rusty shifters.
Posted by Don Stauffer on Friday, November 25, 2016 8:51 AM
I have also used the wire brush wheel for my Dremel, both installed in the Dremel and sometimes just holding the shank and brushing the file with it.  But I usually use the brass hand brush, as I suspect the dremel wheel, with its steel teeth, hurts the edges on the file.  I don't believe the power tool does the job any quicker, either.
    June 2014
Posted by Tanker - Builder on Thursday, January 5, 2017 11:52 AM
Hmmm;
 Interesting question . For me , hands down it's a Suede Brush . Or a denture brush .  T.B.
Posted by Don Stauffer on Friday, January 6, 2017 10:29 AM
I have also cleaned out the junk with my #11 blade in X-acto knife.  Very time consuming, but it sure does a nice job!
    March 2008
Posted by Caveman on Friday, January 6, 2017 7:35 PM
Hello,
I have been using this stuff.  Meant for sandpaper and the such, but also works for finer files.  The small block I purchased is still 99% after ten years of use.  Saves me a ton of cash on sanding sticks too!
www.leevalley.com/en/wood/page.aspx?p=20192&cat=1,42500
