What kind of masking tape do you use?
    November 2016
Posted by elation on Monday, December 5, 2016 9:57 PM
Do you guys use tapes made for scale models such as Tamiya, Testors brand or other less expensive alternatives from Staples or Home Depot?
    July 2004
Posted by stikpusher on Monday, December 5, 2016 10:50 PM
Tamiya. All the store brands have been less than satisfactory in my experience.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2009
Posted by Cadet Chuck on Monday, December 5, 2016 10:53 PM
Roger that!
    March 2010
Posted by Nathan T on Monday, December 5, 2016 10:54 PM
Tamiya only.
    July 2013
Posted by steve5 on Tuesday, December 6, 2016 12:16 AM
as above
    November 2016
Posted by Gerhard on Tuesday, December 6, 2016 6:22 AM
What they said ^^^. Only Tamiya.
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, December 6, 2016 9:29 AM
I use Tamiya as well. I also use yellow Frog painter tape as well with zero issues. Walmart has them in green and blue as well.
    January 2009
Posted by fermis on Tuesday, December 6, 2016 9:34 AM
I use Tamiya on canopies and along edges that will be painted, cheaper whatever brand masking tape as filler beyond the Tamiya tape. I'll also use the cheaper tape to hold parts together (fuse, wing halves, etc).
    August 2013
Posted by Jay Jay on Tuesday, December 6, 2016 9:49 AM
I don't know why Tamiya is so much better than any other masking tape i have tried but it just is. I use it on every critical area for painting. it always comes off clean and with sharp edge lines and doesn't lift the paint underneath it.
If there is a better, cheaper tape out there, I'd like to know about it.
Posted by Don Stauffer on Tuesday, December 6, 2016 10:34 AM
Jay Jay
It is very thin, compared to most general purpose masking tapes.  I think that may help it conform to surfaces better.  It is made in a variety of widths too, so it is great to have several widths on hand- makes masking a model of varying shapes easy, without having to cut as many pieces as you would need from wider gp tapes.
    January 2009
Posted by fermis on Tuesday, December 6, 2016 12:05 PM
I'll add a little, regarding Tamiya tape.
You can cut thin strips (down to less than 1mm) and they will "bend" enough for curves...think, masking a prop spinner, cowling, nose, yellow bands for bombs, tail bands, etc.
It also works great for making seat harnesses. It allows you to make twists and bends easily...I prefer it over PE belts. I usually cut the hardware/buckles off the PE and use them with the tape.
    May 2008
Posted by ejhammer on Tuesday, December 6, 2016 3:29 PM
The only thing I ever used I liked better than Tamiya, was a vinyl sheet of ship waterline masks that were cut from the same stuff as canopy masks. Was made by Gator's. I don't think he makes the waterline stuff anymore though, so I've had to trim some of the wider strips down and have even used the "waste" around the edges of the sheet. Sure wish I could get more of that stuff. 3-M makes a very narrow vinyl masking. I've got a roll but have not tried it yet. From Micromark. EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    January 2014
Posted by jelliott523 on Tuesday, December 6, 2016 4:43 PM
fermis
Ditto
    July 2004
Posted by stikpusher on Tuesday, December 6, 2016 4:58 PM
The big plus for Tamiya in my book is the adhesion qualities. It stays in place securely, yet is low tack. I tend to leave masking tape in place for prolonged periods and every other brand I have tried tends to become more difficult to remove the longer it's left in place. And long or short term, they often leave residue. Those have never been issues for me with Tamiya tape. It also is far less likely to pull up any paint underneath that has dried and cured. The only exception to that being Model Master Acrylic on an unprimed surface. That stuff will come up easily if you stare at it too hard...
       - Plankton
LSM
    November 2016
Posted by elation on Tuesday, December 6, 2016 7:01 PM
Alright, I will try Tamiya tapes!
Thanks everyone!
    June 2014
Posted by Tanker - Builder on Tuesday, December 13, 2016 9:23 AM
Hey ;
 Can I do a Super Ditto ? Best tape I have ever used !  T.B.
Posted by Bish on Tuesday, December 13, 2016 9:47 AM
Tamiya as well for me.I also now use their new flexible tape for curves.
Posted by Don Stauffer on Tuesday, December 13, 2016 9:57 AM
Bish
I have had some problems with that stuff. If I put too much curvature into it, it wants to lift.
Posted by Bish on Tuesday, December 13, 2016 10:25 AM
Same here Don. Its ok on gentle curves,m certainly better than normal tape. But even on an aircrfat nose i have to do it in sections. Certainly not perfect.
    June 2014
Posted by Tanker - Builder on Thursday, December 15, 2016 9:24 AM
Elation ;
   Although , as I said I do use Tamiya's different sizes of tape , I also use Automobile striping tape if it requires tight curves . Then back that up with Tamiya .  T.B.
    September 2011
Posted by falconmod on Thursday, December 29, 2016 1:59 PM
I've been using the yellow frog tape from Wal-mart for about two years now,  i love it,  I guess cuz I'm cheap.  I'll use regular masking tape for holding other things together.
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    March 2013
Posted by patrick206 on Friday, December 30, 2016 11:24 AM
I've tried so many, agree that overall Tamiya is the best. But I have had really good results for tight curve masking, with one called "Duck" brand blue tape. I cut it into ultra thin strips, it will conform to and hold a very tight curve, haven't encountered residue remaining, clean line separation.
Made in USA, bought it either at hardware store or Wally World. Cheap, works, happy. But, still it's 90% Tamiya for me.
Patrick
    April 2016
Posted by Hodakamax on Friday, December 30, 2016 5:51 PM
I think I got the message! Tamayi tape ordered today. Some of my most famous disasters have been masking problems like paint pull up and seeping under. Thanks guys, I'll give it a shot!
Max
    April 2009
Posted by bushman32 on Monday, January 2, 2017 7:07 PM
What is the trick to using Tamiya tape? I have several rolls and I have the worst luck getting it to stick. Many times I have to resort to masking tape. Ron W.
Ron Wilkinson
    September 2006
Posted by the Baron on Thursday, January 5, 2017 11:20 AM
bushman32
Well, it's supposed to be low-tack, so it's not as sticky as blue painter's tape or masking tape (ascending order of adhesion).  I burnish it down with a finger, or the tip of a paintbrush handle or a toothpick, depending on the situation (eg, toothpick when masking a 1/48 airplane canopy).
I won't go back to masking tape, which I find too tacky, even when you use the trick of sticking it to something to remove some of the adhesive.  It's too easy to damage the surface below, if you use it over paint, or to leave adhesive residue behind, which you have to clean up.
Have you thought about using masking fluids?  You apply them, paint, then peel the mask off?  That might work better for you.
Best regards,
Brad
    February 2007
Posted by mitsdude on Monday, January 9, 2017 12:55 AM
Whatever masking tape you use be sure to keep it clean.
At one time I kept all my tape loose in a plastic box. I looked at the edges and there was all kinds of crap stuck to the sides of the tape. Nicks and dents too. These problems can allow paint to leak under the tape.
I now keep each roll in an individual zip lock bag and I'm careful about tossing it around.
    July 2013
Posted by steve5 on Monday, January 9, 2017 2:54 AM
excellent point mitsdude , never thought of that .
    July 2014
Posted by Bakster on Monday, January 9, 2017 9:52 AM
I'll second what Mitsdude said. I am currently using up some tape that had been placed on a dusty table. The edges of the roll picked up all kinds of junk, even cat hair. Now, when I am masking, I have to pull off all that garbage because it could get plastered down into the paint during airbrushing. It's a pain, and I made up my mind that I won't make that mistake again. Keeping the tape in a zip lock bag is a great idea.
To the OP's question: I use Tamiya tape. It has just the right amount of stick to it. For non-critical jobs, like to mask off for overspray, I will use painters tape. It is less expensive to use.
    April 2009
Posted by bushman32 on Monday, January 9, 2017 3:57 PM
Thanks for the input on Tamiya tape. I do keep my tape in bags. Sometimes I don't clean the newly opened plastic, and when I do, probably not good enough. I use masking liquid when I don't need straight lines, such as waterlines. My feeling is I need to clean the plastic of mold release better and better burnishing.
 Another question, how does Testor's tape compare?
  Ron W.
Ron Wilkinson
Posted by Don Stauffer on Tuesday, January 10, 2017 6:34 AM
bushman32
  Ron W.
I have used it- 1/16 width version.  It works and was narrower than Tamiya offered at the time. It works okay, but it is not as good as Tamiya.
