The key to the UV adhesives---no snarkiness intended---is that the UV has to be able to get to pretty much all of the resin for it to cure properly. When it can do that, it's nice and strong. Great for p-e, and especially for clear parts.
I spent this afternoon installing windows in the fuselage of a Williams Bros. Boeing 247, and it made the job much easier. Once I got the pieces to fit to my liking, a little squeeze of "5-Second Fix" on the tiny flange edges, pop the piece in and squeeze it firmly into place---then wipe away any excess with a swipe of tissue before hitting it with the UV. It locks the pieces instantly in place, and is strong enough to resist incidental handling...which the PVA-type clear part adhesives are not.
I've also found it has about the same hardness as styrene when cured, and sands pretty cleanly. I've even fine-sanded/buffed/polished it to good clarity after sanding, just like clear styrene.
Very handy stuff!
