CA question
    January 2004
CA question
Posted by Mogwa on Monday, March 29, 2004 3:51 PM
Im about to start my first model in 20 years. I got a PE set for it and it will be the first time Ive ever used PE. My question is I bought a bottle of CA at the hobby store and now I notice the label says plastics and hardwoods in small letters on the label.[:0] I picked it out of a lineup of several bottles of CA becuase the label says in large letters extra thick- 15-25 sec glue. Well I picked this one becuase I didnt want the 1-3 second bottle on my first try. So, is this stuff going to work, even though it says plastics and hardwoods?
Thx,
Mog
UH-60 Crewchief / Technical Inspector and Modelling Addict
Posted by midnightprowler on Monday, March 29, 2004 3:53 PM
Yes, it will work.. Use very small amounts, as it can create a white "fog" on the part. I use 5 minute epoxy, and sometimes clear enamel for pe, depending on where is is going, and on occasion, super glue.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Thursday, April 8, 2004 3:27 PM
Try the Zap a Gap CA glue. It comes in different thickness. The thicker the longer the drying time.... My favorite hobby shop, King's here in Austin. Said their most popular is the medium thickness.
Good Luck and Have fun Smile [:)]Big Smile [:D]Cool [8D]
Posted by MikeV on Saturday, April 10, 2004 7:50 PM
Actually the name, "Zap-A-Gap" refers to the CA+ medium version of their glue in the green label and not the brand name. The brand name is Zap and they make many different versions as was mentioned. Wink [;)]
    August 2003
Posted by tweety1 on Saturday, April 10, 2004 9:39 PM
Personally I use both the Pink Zap and Green.
With the pe, the pink is used mostly on my bench due to it's extremely thin water like consistency, if too much is placed onto an item, it can be wicked away with a piece of paper towel.
I find the Green useful on pe parts such as small 'boxes', or even crosshairs where you need a little more 'hold' at the base, but I dont find it too useful for items such as seatbelt sashes, or attaching panels to flat surfaces due to it being 'thicker'.
The pink is also useful for joining fuselage halves, or tank hulls, where the fit is not quite 'spot on', this stuff will flow along the join and hold it in place perfectly giving you time to place your normal plastic glue where it's needed.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by MikeV on Saturday, April 10, 2004 9:59 PM
Good points Tweety1.
I also have the pink label Zap and like it for some things, but find it more difficult to work with because it is so thin. Gluing one's own fingers is common with that stuff as it is like water. Wink [;)]
    August 2003
Posted by tweety1 on Sunday, April 11, 2004 1:16 AM
Laugh [(-D]
Your right on the fingers part.
When I first tried it I didnt buy the debonder.Oops [oops]
I now know the debonder is an ESSENTIAL part of the Zap processWink [;)]Smile [:)]
Posted by MikeV on Sunday, April 11, 2004 1:35 AM
Actually, fingernail polish remover or acetone will unglue your fingers from CA.
    August 2003
Posted by tweety1 on Sunday, April 11, 2004 10:19 AM
True, it will separate your fingers, but you can't use it for removing CA glued items from styrene, and if your fingers are glued to the styrene item, then you need the debonder.
Posted by MikeV on Sunday, April 11, 2004 11:08 AM
That is true. Wink [;)]
