New small Dremel
dlh
    March 2017
New small Dremel
Posted by dlh on Wednesday, August 22, 2018 10:35 AM
Picked this up on a whim.  It's good at reaching small areas with 800 grit burrs that I got elsewhere.  It claims 5K RPM is slowest, but feels slower than that. Small and lightweight; not a lot of torque, but that's not needed. Not as agressive as my cordless Dremel and, of course, my corded beast.
https://www.dremel.com/en_US/products/-/show-product/tools/2050-stylo-versatile-craft-tool
    July 2014
Posted by Bakster on Wednesday, August 22, 2018 11:45 AM
It looks like it fits in the hand nicely. Just curious. What kind of power switch does it have? Is the switch part of the speed control? A separate switch? Is it on and off? Or do you have to hold the button down for it to operate?
dlh
    March 2017
Posted by dlh on Wednesday, August 22, 2018 12:39 PM
Bakster
Separate power button; push on, push off.  Speed selector is separate (1-5). It uses a wall-wart so power cord is light weight.
    July 2014
Posted by Bakster on Wednesday, August 22, 2018 3:33 PM
dlh
It sounds like, and looks good. I think you will enjoy it. I us my RT a lot. For grinding, cutting, even drilling. I suppose even polishing.
Enjoy it!
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, August 22, 2018 8:43 PM
I’ve been eyeing that as well. Lowe’s had it on sale last week for $30. Should have grabbed it when I had the chance. Now regular priced at $60.
Posted by Don Stauffer on Thursday, August 23, 2018 7:01 AM
What size is the chuck?  1/8 or 3/32?
dlh
    March 2017
Posted by dlh on Thursday, August 23, 2018 9:12 AM
Don Stauffer
1/8, but uses the same collet system as other Dremels.
    August 2005
Posted by EdGrune on Thursday, August 23, 2018 10:42 AM
Keep an eye out in Lowes.   Its getting to be that time of year.   Dremel marksts a version of their mini-mite tool for pumpkin carving.  Its is a 4xAA battery powered tool, 2 speed, 1/8 collet tool.  (Hint, when the batteries are tired the motor turns slower).  In addition to standard black plastic I have seen them with transparent green and transparent orange shells.    They are sold at Lowes and often go on clearance sale once Halloween is over.  Buy it when you see it on sale, goes quickly.
I have one and use it occasionally.  I have found that a Dremel, even at slow-speed, is a fast way to screw something up.
    September 2012
Posted by GMorrison on Thursday, August 23, 2018 10:57 AM
I don’t use Dremels much because they are too fast for plastic.
Helpful post though.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, August 23, 2018 11:07 AM
GMorrison
True. But it can make trimming parts off resin sprues / blocks easy.
dlh
    March 2017
Posted by dlh on Thursday, August 23, 2018 11:22 AM
GMorrison
I totally agree.  This unit doesn't seem to be as fast.  I've used it with 600 grit burrs to get a start on hard to reach ejector pin marks.  A light touch didn't melt and was easier to finish up with a small PE sanding tool from RB Productions:
http://www.radubstore.com/index.php?main_page=product_info&cPath=77_164&products_id=670
dlh
    March 2017
Posted by dlh on Thursday, August 23, 2018 11:24 AM
EdGrune
Definitely.  Learned that the hard way. Crying
    July 2014
Posted by Bakster on Thursday, August 23, 2018 11:42 AM
dlh
Very true. I tried using it to drill the fins on my Seaview. The drill created enough heat to melt the plastic. I didn't see that one coming because I have used it to drill other things without a problem. It was the depth of the piece that caused the issue. But, aside from some obvious limitiations--I still use it a lot. I wouldn't be without it.
    April 2005
Posted by ddp59 on Saturday, August 25, 2018 2:28 PM
GMorrison, get an external speed control as that is what i have to use on my 40yr old dremel as it does not have 1 built in so it just has 1 speed of approx 28k rpm. it can go from a dead stop & goes upto full speed or in between depending on the dial rotation. i use mine to carve stryene plastic carefully so as not to melt plastic or take hunks out.
Posted by Don Stauffer on Sunday, August 26, 2018 6:42 AM
GMorrison
My battery one, several years old, can turn so slow you can see each revolution.  And, the speed regulation is not that great- it slows down with load.  So I have no problem working with plastic.  I am looking forward to the one of this thread, though, because my existing Dremels are just too big and heavy.
    February 2011
Posted by 40kminis on Wednesday, August 29, 2018 10:59 AM
Anyone use this? Great for plastics, only downside I have found is you have to hold the button down for it to spin.
http://www.trumpeter-china.com/index.php?g=home&m=product&a=show&id=2692&l=en
Posted by Don Stauffer on Thursday, August 30, 2018 8:11 AM
Is this thing really 6 or 7 ounces?  That seems like a lot for such a small tool.
