Cutting/Engraving?
    November 2015
Cutting/Engraving?
Posted by STOVK on Thursday, August 23, 2018 4:11 AM
Hello All,
Seeing that a Laser Cutter is out of my budget, I was wondering if anyone had any suggestions for an alternative cutting machine?
What I would mainly be using it for would be cutting stencils and shapes.
For example: I want to make some raised lettering which would be on a wall of a diorama I am building. If I design a sign in CorelDRAW, I would like to export the SVG/EPS file to a cutter to make that design.
I would like to be able to cut thick card stock and styrene sheets.
I was looking at the Brother ScanNCut CM650WX but the thickness for the material I was looking at was limited to about 0.2mm. I was wondering what other products are out there which could be better and be able to cut thicker material?
Any help would be appreciated.
As always, thank you in advance.
Posted by Don Stauffer on Thursday, August 23, 2018 6:56 AM
I have a Cricut machine.  It cuts vinyl fine, still working out setting thickness for cutting styrene.  It works okay, but my CAD needs to be a bit better- better accuracy for corners.  I originally got it to make paint masks, but when I found it would also cut thicker materials like sheet vinyl and sheet wood I started planning to make actual model parts.
Problem now is that the version of the CAD I was using won't work on my Windows 10 machine and they raised the price so high I can't afford the latest version.  All the cheaper CADs I find are hard to use and I have to learn a new one.
There are several cutters similar to Cricut, some used by people on this forum.  Google "vinyl cutters."
    November 2015
Posted by STOVK on Thursday, August 23, 2018 8:17 AM
Don Stauffer
Cricut, huh? I'll check into it. What is the maximum thickness for the wood which produced good results? Have you tried cutting wood veneer?
How clean are the cuts on the wood products?
Thanks again.
p.s. Just curious. I never used CAD. Why would that make a difference in your final cuts? I use CorelDRAW and I was figuring on creating a design and exporting the file in SVG or EPS format.
    November 2015
Posted by STOVK on Thursday, August 23, 2018 11:02 PM
Ok, so I've been doing a little more research and I came across this product called the Silhouette CAMEO 3. It appears to be a little more robust.
Does anyone have any experience with this product?
Posted by Don Stauffer on Friday, August 24, 2018 7:01 AM
STOVK
Don Stauffer
Thanks again.
The upload to the online translater requires jpeg.  My problem is that not all of my corners meet, and difficulty of getting lines parallel and square like I wanted.  This is due to lack of options on the cheap cads I have been trying.  The machine is a robot. It will not fix errors in drawings.
    January 2015
Posted by PFJN on Friday, August 24, 2018 11:11 AM
Hi,
I only have the Silhouette Potrait, but I have been very happy with it.  It imports CAD type DXF files, though there is a default parameter that you have to reset to tell it to not rescale the file to fit.  The first couple times I tried to cut something I couldn't figure out why they were the wrong size, but once I found out about the import paramter (by searching the internet), everything else seems fine.
Pat
1st Group BuildSP
