Building Clamps
    September 2010
Building Clamps
Posted by mvaldeslora on Monday, December 24, 2018 4:26 AM
First, a wish to all for a joyous and merry holiday season and a wonderful New Year!
Next a question. What is your preferred way of clamping pieces for gluing? I guess I am thinking mostly of plane fuselage halves, wings, and the like.
I liked the old Berna clamps but a number of the rubber feet have cracked and come off and I cannot find replacements.
Thanks for your suggestions.
Mario
Posted by Bish on Monday, December 24, 2018 4:46 AM
I use a mix of small bar clamps and spring clamps depending on what i am doing.
Posted by Don Stauffer on Monday, December 24, 2018 9:08 AM
In addition to spring clamps and bar clamps, I keep a supply of wood clothespins.  I will occasionally tape parts together with masking tape if I am using gel CA, but even with the gel, the glue can wick out and damage the surface, is this is only very occasional.
In addition to the regular clothespins I keep a supply of miniature ones.  I got mine from Model Expo, but Michaels has them now.
    May 2008
Posted by ejhammer on Monday, December 24, 2018 9:21 AM
What are these?? can you show a picture?
EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    May 2013
Posted by Greg on Monday, December 24, 2018 10:53 AM
My fingers and patience.
Clamps have routinely caused me trouble. I think I need to take clamping lessons.
    September 2010
Posted by mvaldeslora on Monday, December 24, 2018 2:57 PM
I found this pic on the net. It gives the general idea. They used to come in several sizes.
https://goo.gl/images/fpFHUq
    September 2010
Posted by mvaldeslora on Monday, December 24, 2018 3:00 PM
I know what you mean, Greg. I have the same problem and hence my question. I have picked up a number of alternatives over the years but none seemed to do the trick. Like I said, the Berna clamps came closest to being useful for me but over time the rubber ”feet” have degraded. I thought there might be something out there I was missing.
    March 2015
Posted by JohnnyK on Monday, December 24, 2018 3:19 PM
I use a variety of clamps.
This a P-38. I used plastic clamps with soft tips, laundry pins and a small adjustable bar-clamp. Sometimes I also use rubberbands.
Posted by Don Stauffer on Tuesday, December 25, 2018 7:01 AM
JohnnyK
That looks like some of my builds.  I use all those types of clamps.  The bar clamp with the orange pads looks like the clamps from Harbor Freight. I have some of those, plus some Irwin versions I got when my local Menards had them on sale.
    September 2010
Posted by mvaldeslora on Tuesday, December 25, 2018 7:39 AM
JohnnyK
Thank you JohnnyK. I think your pic shows there is no magic bullet.
    August 2013
Posted by Jay Jay on Tuesday, December 25, 2018 8:05 AM
I bought a set of 6 of these Berna type clamps at a flea market for 2 bucks. They have flat cork pads instead of the formed rubber but they seem to work well.
    March 2015
Posted by JohnnyK on Tuesday, December 25, 2018 9:06 AM
The cork may be better than the formed rubber pads. The rubber pads are slippery.
    August 2013
Posted by Jay Jay on Tuesday, December 25, 2018 9:41 AM
No complaints so far. The cork grips pretty good but I had to re-glue them all to the frame, no biggie
    September 2010
Posted by mvaldeslora on Wednesday, December 26, 2018 7:10 AM
Hi Jay Jay. That cork idea sounds pretty good. I may need to try that. Would you be able to post a pic of what they look like? Thank you.
    August 2013
Posted by Jay Jay on Wednesday, December 26, 2018 7:58 AM
Right now, I can't post pics, I got a new computer with an unfamiliar ops, but I'll try and work on it.
    September 2006
Posted by the Baron on Wednesday, December 26, 2018 4:07 PM
I have been using spring-loaded clothespins, and those plastic clamps shown in the picture above.
Clothespins have worked pretty well for me, but I think they cause the open seams or gaps that I've been getting on airplane wings.  I think the springs provide too much pressue, and they squeeze the wings enough to open the seams while the glue cures.
Those plastic clamps slip off too easily.
I think that for that particular application, gluing upper and lower wing parts together, I can get away with using rubber bands.  That should be just enough pressure to keep the parts in place, but not to open the seams, as the glue cures.
I also use clothespins and those plastic clamps as ad-hoc handles for parts or figures as I work on them.
Posted by Don Stauffer on Thursday, December 27, 2018 8:53 AM
Be careful with liquid cements and rubber bands.  The bands will promote wicking of the cement onto the exterior surface.  Highly cambered wings do present a problem.  You cannot clamp easily near the edges, but clamping in the middle will warp the parts leading to gaps in the edge.  Those mini-bar clamps are nice for this because of the fine adjustment.  You can apply just enough pressure to hold the parts together, but not enough to warp the parts.
    October 2016
Posted by DasBeav on Thursday, December 27, 2018 11:19 AM
Not a clamp answer, but on some wings I do, I wedge them between books. Go to the bookcase and wedge them in. Manipulate the books so there is equal pressure. Works for me!!
 Sooner Born...Buckeye Bred.
    July 2018
Posted by Tickmagnet on Friday, December 28, 2018 9:32 AM
I use Tamiya extra thin cement on the wings and fuselage which works quickly enough to negate having to clamp.
    March 2015
Posted by JohnnyK on Friday, December 28, 2018 10:57 AM
This is something else that can be done with clamps and rubber bands. The wings on my B-24J  were warped. I clamped  an architect's scale to the wing while the glue cured. Worked great. An architect's scale is always super straight and will not bend under pressure.
