Cutting Surfaces
    June 2014
Cutting Surfaces
Posted by Tanker - Builder on Monday, January 28, 2019 9:35 AM
  This will be short .
    Do you have a good self healing cutting mat ? Great . Now sometimes we need something really hard to cut on. What do you use ?
   I have two go to surfaces for this . One is a piece of TEMPERED glass from a salvaged Stereo tower door. The other besides my mat ? well , it's a sample of a counter top .from Home Depot . It is great for this .Also both allow a totally level cutting surface .
     You can use a piece of marble too , or a sink cut-out from a countertop . I have a work surface that is over 38 years old .It is a vanity top made from Corian . It's frost white in color and very durable .Every two years I take the palm sander and clean it off . It gets some cut marks on it from time to time .Paint and glue too .
  You can sand Corian then ,Polish it to a high shine if you like . I don't polish mine when I am finished dressing the surface with 600 grit wet-or dry paper .
   This way I get no glare from the surface. It's heavy , but portable and there have been times it sat on a wooden T.V. Table as my workspace . Ah the open road .Yep , I even modeled when on the road in our fifth Wheel . That was before the Toy Hauler with a rear Garage ( Shop ).
  Good luck . T.B.
    November 2008
Posted by plasticjunkie on Tuesday, January 29, 2019 6:47 AM
I have two self cutting mats but don’t like using them at all. I have a piece of clear glass that I have on my workbench. It’s great for cutting decals and wiping off spills. If a paint or glue spill dries hard it can be easily scraped off with a single edged blade.
For cutting pe I use a scrap bathroom wall tile as the cutting surface.
 GIFMaker.org_jy_Ayj_O
    July 2018
Posted by Tickmagnet on Tuesday, January 29, 2019 7:39 AM
I have a cutting mat. I also have a piece of glass but haven't used it since I got the cutting mat, but it's still there if I find I need it for something.
    September 2017
Posted by Strongeagle on Tuesday, January 29, 2019 8:49 AM
Ahoy T.B. My general purpose surface is a self-healing mat, but when I need to cut tape for masking, i use a piece of plexiglass. I find it a little bit softer than glass and easier on blades. When the scratches begin to annoy me, I smoothe them with some 2000 grit sandpaper.
Posted by Don Stauffer on Tuesday, January 29, 2019 8:46 PM
For a hard surface I use a 4 x 4 block of mdf.  I find it hard enough for cutting PE from sprue, stuff like that.
    June 2019
Posted by Neuman on Sunday, June 16, 2019 3:08 PM
Same. I have a cutting matt. The top of my hobby bench is covered with an old stereo glass door. I also have the glass from a picture frame as my primry work area. Easy to scrape off dried glue, paint, putty, ets.. I do most of my tape cutting on the glass with a rounded tip xacto blade.
    June 2014
Posted by Tanker - Builder on Friday, June 21, 2019 12:23 PM
Ya Know, Neuman;
 Tis funny that you should say that. I still have the glass on top of my bench area I got from an old Stereo Stack. Remember those? Nice part?There's a little label imprinted in the glass indicating it is Tempered Glass .
    September 2012
Posted by GMorrison on Friday, June 21, 2019 12:59 PM
In my line I have my manufacturers/ fabricators produce sets of four of 6"x6" aluminum plates painted various colors. I keep one, the onsite folks keep one, the architect keeps one and one goes back when approved for quality control. I have thousands of the things. They are usually natural aluminum on the back, and extremely useful. Generally though I work on a self healing mat or a piece of "masonite".
My NWSL "Chopper" has a masonite bed, but it's developed a slot where the blade comes down. I can't really figure out a way to fix that since it's all riveted together.
    May 2011
Posted by Real G on Friday, June 21, 2019 1:04 PM
I have a broken piece of jalousie glass that I have used since high school.  The broken edge is so worn that it is no longer a hazard.  But the surface is really scratched up now, and the textured backside makes it hard to see the small stuff.  I should upgrade to a nice manufacturer's glass sample, since I work in an architectural office.  We also get lots of ceramic tile samples, so I should get one of those too for soldering, my next modeling adventure.
“Ya ya ya, unicorn papoi!”
    November 2008
Posted by mrmike on Friday, June 21, 2019 1:11 PM
Like some of the rest of you, I have a mat, but never use it for cutting. I find that glass works really well for tape and sometimes PE, chipboard for general cutting, and like TB I really prefer Corian for most things. Mine came as cutoffs from a counter top fabricator; I'll wet sand them when they get scored and they're good as new. The two pieces I have are twenty years in service and still plenty thick.
    June 2019
Posted by Neuman on Saturday, June 22, 2019 11:28 AM
I remember those well. DIY stereo cabinets. I wonder how many of those old glass doors found another use years after the cabinet was gone?
    September 2006
Posted by the Baron on Saturday, June 22, 2019 2:47 PM
I use a cutting mat, but also glass plate, too.  Mine are pieces salvaged from digital equipment-copiers, fax machines, scanners, etc.  I have a friend who recycles digital equipment, and he saved me those glass parts.
I use a piece of glass plate as a work surface for working with epoxy putties, too.
