Sanding Materials
    June 2014
Sanding Materials
Posted by Tanker - Builder on Friday, February 15, 2019 1:04 PM
Hi !
 Listen I will try tto make this shorter in length . So , If I forget something , or you have something to bring to our attention , Please ! Do So !
     You know many years ago I met my first piece of sandpaper .Dry , messy , dusty and totally unsatisfactory except for removing a gross amount or material .You could have glued pieces of this stuff to a bald tire  and increased it's mileage !
   Years later , after learning about the various grits from superfine to extra coarse I graduated to Wet-or Dry ! What a relief . No dust and I could actually sand under water ! Now the sizes here went from very , very coarse to so fine that when dry you couldn't feel the grit .
    This leads me to the main intent of this letter . Sanding Boards ! Many of the hobby distributers and hobby manufacturers have gone here, even to the point that if you buy them out of the container at the register they even say Squadron , or some other well known hobby name on them .
 This is all well and good but the range is still limited as to Grits and Quality ! I have found , for the general usages , you can do well by acquiring them from Beauty supply houses today . They come in long rectangles with the grits painted on the face and it gets as fine as what would be a polishing board ( Let's see , that would be 8,000 grit )
     Some , like their hobby counterparts have rounded ends . the ones I get look like planks of sanding material with two grits to a board .Also , and this is important, you can put a steel rule on them and split them length-wise ! So for future thought Include Sallys and other beauty Supply houses as another source of Sanding , painting and weathering supplies .
     Now for you die-hards .If you can't get to a Tru-Value or Ace hardware you are out of luck .I've not seen anything like this at Lowes or Home Depot . Harbor Freight sometimes .  I say this because I have a Micheals , Hobby Lobby and Joannes within driving distance , but they don't always have these items in stock .
   Hobby - Town is 47 miles away and they don't always have these types of items in stock either . So It's Ulta or Sally's for me .the Colors of finger-nail polish will cause Auto Builders to become comatose , There's that many ! So , in closing , don't short yourself on sanding supplies and remember Body Shop supply houses are always an option if they will sell retail ! Bye -T.B.
    August 2014
Posted by goldhammer on Friday, February 15, 2019 1:14 PM
I like to use the gray "scotchbrite" pads from the auto paint suppliers to give a light scrub to thesurface before priming.  Also a quick rub with them after prime and before paint. Flexible enough to get in panel lines, etc.  Can cut to strips with scissors and a couple of pads will last quite awhile.
They leave the surface with enough "tooth" to help with paint adhesion, without showing scratches in the finish.
If on good terms with your local body shop, you can probably talk them out of a couple, or get at most NAPA or big auto parts store or auto paint supply outfit.
    July 2018
Posted by Tickmagnet on Friday, February 15, 2019 2:16 PM
Check the make up department at Wal-mart or any dept. store and you may find them there as well.
    August 2013
Posted by Jay Jay on Friday, February 15, 2019 5:18 PM
Forget buying expensive hobby sanding sticks, you can make your own for cheap. As a base , thick plastic strips or tongue depressors, or craft sticks can be used make to any shape and size desired. On both sides of the base stick on double sided foam weather strip tape and then any type or grit sandpaper can be used. Cut it all down with scissors and there you have it. They're so easy and cheap to make I can't understand why one would buy any.
    June 2014
Posted by Tanker - Builder on Sunday, February 17, 2019 9:27 AM
Well Now J.J.
 That's mean to say I think  He, He . Why ? well ya caught me alright ! I never even thought about doing it that way . Hitting me upside the head was the right thing to do . Thank You Sir for a Great Idea ! T.B.
    August 2013
Posted by Jay Jay on Monday, February 18, 2019 4:44 AM
Just another friendly tip from your Uncle Jay Smile
    July 2019
Posted by Robotism on Tuesday, July 23, 2019 12:28 PM
Jay Jay
I tried tongue depressers and wasn't very happy with the result. Even though I was sanding a flat surface with a flat stick I couldn't apply the entire stick to the piece. It just didn't want to line up with the surface. I also had a few sticks warp from the glue. Ended up binning the lot of them.
I really like Albion Alloy's cut up sanding sticks but it's a swine to find them whole. The package lists grits and I picked up sandpaper matching that grit and it was far too coarse. The 320 grit stick is sanding far closer to 1000 grit sand paper than 320 grit paper. It's really confused me on this whole thing. I want to pick up some sanding sticks but the grit thing seems unreliable when ordering. I like sanding sponges but sticks are much easier to control.
Does any one have any recommendations for a good sanding stick that will remove a decent amount of material but not leave marks on the plastic? Not a fan of having to go through 5 different sticks on a plastic kit.
