Well ;
here's my report on Gator's Grip Glue. One - it comes in a bottle with a twist seal cap!
Two - It's thinner than Aleens or Elmers! Three - It's a heck of a lot stickier ! Four - It's a lot easier to use in the bottle. Also, take a squirt an put it on a credit card( the ones that ARE Plastic, and come unsolicited in the mail) A Pallette, if you will.
You can then work with the glob for about ten minutes. This is a glob the size of a small marble. It Will skin over, but, you just keep sticking your tool or toothpick in the glob to get workable glue.
I got about ten more parts built in the time I usually spend for one or two with Aleen's, and No parts drift while drying! The Rails? Well, did a trial with some damaged rails on a scrap. Once on, they tore the paper out in a gout trying to remove them after ten minutes.
I highly recommend this glue for P.E. and Card or Paper models I got mine from Michigan Toy Soldier in Royal Oak, Michigan.
