Punches
    July 2014
Punches
Posted by Bakster on Monday, March 7, 2022 10:39 PM
Well, I added a new tool to my arsenal. My main purpose in getting them is for making circular masks. How many times I tried to freehand circular masks and they were far from circular. Forget about it.
I tried the punches tonight and they worked like a charm. The set even comes with a pad to punch against.
https://www.amazon.com/dp/B07ZFF143H?psc=1&ref=ppx_pop_dt_b_asin_title
    August 2005
Posted by EdGrune on Tuesday, March 8, 2022 8:03 AM
I use this Harbor Freight Punch & Die set quite often.  Sizes range from 1/8 to 3/4 inch.  I cut wheel masks for A/C.  I've used the larger sizes to mask the deck inside of 350 scale gun tubs
Micro Mark also sells a small sized one in sizes up to 1/8
    March 2022
Posted by missileman2000 on Tuesday, March 8, 2022 8:14 AM
I didn't realize HF had them.  That looks like a very nice set- how much?
    July 2014
Posted by Bakster on Tuesday, March 8, 2022 9:14 AM
EdGrune
Hey Ed-- that does look like a nice set and these would punch through metal even. I might conider it for other things too. For my purposes, I needed them for softer material but the bigger issue for me is that I need them smaller.  This HB set starts at 1/8" and this is too big for my needs.
Don-- the link is below. $34.99ea
https://www.harborfreight.com/9-piece-punch-and-die-set-95547.html
EdGrune
I looked at them prior to buying what I did. The punches I wanted before shipping is pushing near $60. Too expensive for my purposes. Link below.
https://www.micromark.com/Micro-Punch-Set
Link to all their punches/dies
https://www.micromark.com/search?keywords=punch%20set
Speaking of Harbor Freight: I considered purchasing this set if I could have found them locally. The closest store that has them in stock was about 40 miles, one way. The time to travel and fuel distance was not worth it to me. But their price was right at $9.99ea.
https://www.harborfreight.com/9-piece-hollow-punch-set-3838.html
In the end-- the set I purchased suits me better because of the small size range and their small incremental range between each other.
    August 2005
Posted by EdGrune on Tuesday, March 8, 2022 9:32 AM
Yes, at 35 bucks it is a bit expensive as a one-off outlay, but it has lasted for a long time with little wear. It has paid for itself.  HF doesn't have the sale coupons as often as they used to, but check their site often for a discount.
The 1/4 inch punch has worked admirably well punching masks for 1:72 scale Mustang wheels. You could also punch decal faces, but I don't work in 48 or larger.   I have also made base mask for a star & bar decal with the appropriate sized disk and a strip of kabuki tape.
I put a strip of blue tape on a scrap piece of 20 thou styrene and punch that, then peel the tape off the disc.   Could also slice the tape at this point to get halves or quarters as needed.  With some artistic ability I would imagine you could cut a star.
I've tried the hollow leather punches.   They may be acceptable when new, but wear soon resulting in a ragged punch
    July 2014
Posted by Bakster on Tuesday, March 8, 2022 9:46 AM
EdGrune
Good to know. I may end up getting it for larger diameter jobs.
EdGrune
Agreed. From what I read leather punches don't last too long, though this set had decent reviews. I suppose it depends on what a person punches through. I am hoping they will last me Ok by my cutting through tape only. I guess some people sharpen them. Though, I would not know how. At $13 and change, it is worth the try.
Thanks for the info on your HF set!
    July 2014
Posted by Bakster on Tuesday, March 8, 2022 10:11 AM
EdGrune
I forgot that I wanted to comment on this. What you wrote is precisely right! You can hodgepodge stuff together to make a nice clean custom mask. That is exactly what I intend to do with this. In fact-- I have already done so. It will push my masking to a much cleaner level. Yes
    September 2006
Posted by the Baron on Tuesday, March 8, 2022 12:45 PM
I've got MicroMark's Micro-Punch set:
It's useful, though mine isn't marked with the punch diameters.  I had to get from the online catalog that they run from 1.00mm to 5.00mm in .5mm increments.  Not a big deal, though.
I see that MicroMark offers a "Precision Disk Punch Set", now, too:
https://www.micromark.com/Precision-Disk-Punch-Set
That looks like an interesting design. But the Micro-Punch set has served me well, so far.
I also have RPToolz' hex-punch set.  That one is use for making bolt heads and similar objects.  But the design is less-than-optimal.  The punches consist of a piece of hex stock, embedded in a larger cylindrical piece, as the head you tap.  The punches have a tendency to pull out of the tapping head.  Again, useful, but for the price, you'd wouldn't expect that to happen.
