Ultrasonic clearner for airbrush
    December 2005
Posted by Stuart06 on Friday, May 12, 2023 2:50 PM
I have decided to get an ultrasonic cleaner to clean the parts of my airbrush.  My Airbrush is the Iwata HP C+.
For those that do clean airbrushes with an ultrasonic cleaner, I have seen on youtube people clean with water, water and soap, and some commercially available jewlery cleanter.  What would you guys recommend.
I have mostly used my airbrush with Acrylics (Tamiya or Mr. Hobby - Aqueos).  I have used enamals a bit last year, but I figure the hand cleaning that I have done should have taken care of 90% of that.  I know that you cannot put enamal thinner in a ultrasonic cleaner so  i am not worried about that.
Most of my friends are imaginary
Sell your watch, because time is money $$
In Canada hwy speed is measured by number of moose tracks per hockey goal.
    July 2013
Posted by steve5 on Friday, May 12, 2023 6:34 PM
I have the same airbrush stuart , I use windex , or the cheaper version , when I'm finished , I just decanter it back into the bottle for next time .
    December 2005
Posted by Stuart06 on Saturday, May 13, 2023 6:14 AM
but doens't windex have amonia....doesn't that eat away at the plating of the pail of the ultrasonic?
    May 2013
Posted by Greg on Saturday, May 13, 2023 8:20 AM
I also have the Iwata, and have been using my ultrasonic tub to clean it for a long time. I just use a jewelry cleaner powder of some sort for ultrasonic cleaners. When I return home, if I think of it, I'll advise the name of the product.
This may be obvious, but I disassemble the a/b before putting the components in the tray. And yes, I put the stripped a/b body in too.
I have no idea if this procedure is correct, and I am no airbrush expert (we have a couple of them here, but I'm not them), it's just what I've been doing for over 10 yrs, and I'm still using the same Iwata, and it still works as new.
    July 2013
Posted by steve5 on Saturday, May 13, 2023 9:44 AM
I have been doing it for roughly 8 years , and I see no  ill effects , from what i have heard mr badger recommends it .
    December 2005
Posted by Stuart06 on Saturday, May 13, 2023 1:47 PM
Thanks guys,,,for those with Iwata (although it probably is no different for any other AB), I was told to not put the air-valve (the thing at the bottom that the button pushes down on to let air flow) in the Ultrasonic cleaner.  This makes some sense as the little plunger area seems to be greased.
Also don't but in the tip sleeve (the very tiny sleeve at the tip of the A/B that the needle pass through.  They say it can crack....
Anyway, what brand of Ultrasonic do you guys have / recommend.
    July 2013
Posted by steve5 on Saturday, May 13, 2023 5:32 PM
I'm the same as greg , I strip it all down and throw the lot in , I then oil it up when reassembling .
    April 2004
Posted by Jon_a_its on Sunday, May 14, 2023 4:11 AM
As others have said, strip down, but do not put air valve assembly in, it gums up nicely.
US Windex may be fine, (active ingredient is ammonia)
UK Windolene isn't (no ammonia, fine for windows though).
If you think you need more 'oomph' with your cleaning fluids, you can put small parts in a small container (23ml large Tamiya  pot, closed lid) with your volatile cleaner, & put that in the ultra sonic bath.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
