Airplane building stand or berth
    July 2013
Posted by Jon E on Sunday, March 10, 2024 8:08 PM
Hi- new to modeling and I'm looking for suggestions on the best sand or berth to hold aircraft throughout the build. I mainly build WWII and modern aircraft.
I have looked at LMG but reviews are horrible.
Any help is appreciated
Ice
    March 2022
Posted by Jsizemo on Monday, March 11, 2024 8:07 AM
I know there are a number of laser cut wood ones on the market, but I have not always heard good things about them. I myself have built ones out of card board boxes. I have also seen people build them out of legos.
I have ordered a glue holder from this guy. I have seen others use his 3D printed jig, but only issue is he is in the UK so shipping can take a while.
https://bulldogmodels.co.uk/collections/model-jigs
    April 2020
Posted by Eaglecash867 on Monday, March 11, 2024 8:58 AM
I just have a block of Pelican Pick-and-Pluck foam that I use for that purpose.  No need for extra padding on a wooden jig to keep from scratching your model.  It also works well for stuffing inside places where you don't want paint to get in.  I have a large zip-loc freezer bag that I keep all of the various sizes of foam block in after using them, so they can be re-used.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    October 2010
Posted by Pj's thunderbolt on Monday, March 11, 2024 9:59 AM
for cheap just Cut and glue some cardboard or carve one from a block of styrofoam.
There are plastic and wood berths but I have no links for you. The wood one I have is from Czec republic
Posted by gregbale on Tuesday, March 12, 2024 12:38 PM
I've always made a simple 'tripod' type stand from a bent wire coat hanger and paperclips as tiny 90° 'hooks.' Easily adaptable to pretty much any size or configuration of model, allows 360° access for both building and painting, without having to touch or hold the model itself. (But simple to remove if needed.)
For a/c models they go on the stand once basic wing-to-fuselage assembly & cleanup is done -- and usually don't have to be removed until the model is finished, unless something like tricky landing gear alignment is required on a flat surface.
Cheap, versatile, and prevents pretty much any accidental wear and tear to the model! YesYesYes
Greg
George Lewis:
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, March 12, 2024 2:47 PM
On the counter top.....
most often, I use my technologically advanced left
       http://www.sherv.net/cm/emoticons/hand-gestures/whatever-hand-smiley-emoticon.gif
and styrofoam, coat hangers, newspapers.
 https://i.imgur.com/LjRRaV1.png
