Air hose extension
    April 2023
Air hose extension
Posted by John3M on Monday, March 11, 2024 1:49 PM
I would like to add an additional hose to my master airbrush pump. I'm not sure what kind of fixture I would need or extension nut or screw or whatever you wanna call it to add the additional hose onto the existing hose if I could get someone to give me a link so I can get those Joint or union to extend the hose, I'd appreciate it all I wanna do is make this hose longer, so I can use it in a different part of my shop without having to move my pump
Posted by keavdog on Monday, March 11, 2024 2:58 PM
I bought this set and found it to be helpful and good quality.  Maybe it will have the coupler you need
https://www.amazon.com/SAGUD-Airbrush-Connector-Accessories-Compressor/dp/B091K4N7K4
Thanks,
John
    April 2023
Posted by John3M on Monday, March 11, 2024 4:30 PM
Thanks I ordered them. Hope they work out. Appreciate the input
    March 2022
Posted by missileman2000 on Tuesday, March 12, 2024 9:27 AM
To me, it looks like this set only contains metric adapters.  Some times the adapter needed is a British/US thread to metric adapter for US made compressors.  Such adapters are availabe from good hardware stores.  Forget the tread sizes.
    August 2005
Posted by EdGrune on Tuesday, March 12, 2024 11:28 AM
I've used 1/4 inch brass pipes, nipples, and elbows obtained from the local big box hardware store to connect/extend my air supply from my compressor.
Works well, the only problem I've found is that they do not have a model manufacturer's logo affixed.
