Dremel made easy
Dremel made easy
Posted by Anonymous on Sunday, June 20, 2004 1:51 PM
For those of you who use a Dremel or similar rotory tool here's a great tip. I'm sure you've seen the foot pedal potentiometer you can buy as an accessory that are extremely handy but a little pricey. With some basic electrical knowledge you can make this yourself with an old sewing machine pedal. I just spliced a short extension cord through the pedal and plugged the Dremel into it. They are both rated for the same output and the pedal combined with my flex-shaft Dremel extention are what I consider a "super-tool".
Hope this is usefull,
Mahoney
Posted by Anonymous on Sunday, June 20, 2004 2:35 PM
mahoney,
Thanks for the tip. All I have to do is get the foot pedal when the wife isn't looking. LOL I do want to try it as I cut a lot of plastic with a saw blade and this will prevent it from getting too hot.
Richard
    July 2004
Posted by drodrig on Thursday, July 29, 2004 2:47 PM
Thanks for the good idea. I'll have to look for one at garage sales since I dont think I can snag the wifes since she quilts and sews quite a bit. Very cool idea, I was wondering do you set it at the fastest speed and the pot in pedal regulates the speed? Or do you set the speed you want and go.
David
    June 2004
Posted by ewc2003 on Thursday, July 29, 2004 3:52 PM
I also saw a thread about using a type of fan motor controller (for a ceiling fan) to vary the speed of the Dremel. I can't remember who posted though...
Matt ------------------------------------------------- "The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke
Posted by Anonymous on Saturday, July 31, 2004 6:16 AM
Bow [bow]how can ya not just love this forum..........
Bow [bow]GREAT idea mahoney....
Bow [bow]thanks......Big Smile [:D]
    August 2003
Posted by chevit2001 on Tuesday, August 10, 2004 4:25 PM
I've used a dimmer(light) switch with my dremels for several years now to use various speeds. Used an extra extension cord and wired the dimmer switch into the cord. Also made a small outlet box with a dimmer switch to plug various power tools into.
    August 2004
Posted by jdavidb on Saturday, August 14, 2004 10:23 AM
There is such a foot pedal available from micro-mark. It costs around $22 less than the official Dremel one. I don't know if it's really safe for the Dremel though. I might give it a shot. There are two pedals at micro-mark. One is the variable speed that we're talking about. The other is an on/off pedal.
Posted by Anonymous on Sunday, August 15, 2004 2:47 PM
I believe Dremel use to make a variable speed controller way back when. My old man has/had one (haven't seen it around, so it could of busted on him).
Anyways, it was simply a box that you plugged your Dremel into and had a speed-control knob. I used to snag it from the old man when i was younger and it came in very handy.
You 'may' (i use that term cautiously) be able to find one still if you look hard enough.
Posted by Anonymous on Sunday, August 15, 2004 7:07 PM
Posted by Anonymous on Wednesday, August 18, 2004 11:23 PM
All: Be careful doing this if you have a variable-speed Dremel. Word is you can burn the motor of the Dremel out using any foot-feeds, even Dremel's own. Evil [}:)]
Posted by Anonymous on Wednesday, August 25, 2004 6:03 PM
how about getting both pedals? theres an idea for you guys but, its just a thought
Posted by Anonymous on Saturday, August 28, 2004 8:38 AM
how could you burn the motor out ? its not like you are running more current through it .... or have i missed something ? personally i use a flexi shaft and a normal bosh drill for all my dremelling needs. just clamp the drill to the bench, set the speed, press th button and go. free and variable speed
